get that all the time, if they a satchel not a parcel post then the drivers do not drop them off.
and if the guys on the bike do not have enough storage then they just card it.
what really bugs me however is I have a 50/50 chance of which post office, one a pain to get to/park one good.
Hahaha yeah had that all too often, bloody Aus Post.
Never have problems with any courier services though, always knock - hell some of them even gimme a buzz 15mins prior (when I ask)... That's service
Booooo, Odie is still sick... didn't complete the E85 tune. Think the intake manifold is warped, its leaking out the inside edge of the middle gasket between 5 and 6...
I'm thinking it's time for a Plazmaman FFP and a GTR intercooler. Do it right...
Agreed
  • Like 1
How the f**k is E10 98 cents a litre and E85 is 101.9 if the ethanol content in E10 is what makes it cheaper than unleaded
Slowly starting to hate United
going back to the convo we had a few weeks ago..
I think the reason you said was that the market dictates the price....your the market...buy it.
my order from dan's
the courier sms me the night b4 (on australia day) saying he would be there at 10am following day if that worked for me
how good is that!
Mohsen has no insurance.
Not even surprised .
Jesus.... driving around in an $80,000 car (cost, not value) without insurance is a recipe for disaster...
as is owning an $80,000 car (cost, not value)
Cause now the cheapest part of it is the Petrol, not the Ethanol? :P
Edit, clearly wrong, cause that'd make E10 more expensive than 91 in that case.
Yeah it does
I might be wrong but I think Grant possibly did a swap one day? to clear driveways easier or something?
I wouldn't be surprised if my brother has spent 40k or so on his 33gtst (if you include defects and fines etc), and it doesn't even run atm lol
Edited by UNR33L
It's why I sold my 33R was spending too much on it every pay day, at the end of the day was still only worth 20k. Never ending pit of money! I had no control heh.
Edit: at least I had insurance *cough momo*
Edited by UNR33L
I don't even want to know what it's cost me over the past 5 years... if I put my fingers in my ears and hum really loudly, I might be able to pay for a few extra little bits and pieces to get it going again.
All I know is, it's progressed into a real pig to drive, but I love it every time I drive it (especially now that I don't drive it every day)
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
