Drive your ute to Deakin University
Sit there overnight with indomie noodle packs in the tray
Drive back to western suburbs and onto vacant blocks of land
Throw more indomie noodle packs on the ground
Drive home and watch Goodfellas while your property value skyrockets
I like Shark Fin in little bourke, but a bit $$ so not go there often.
for a casual one we go to dragon boat palace on lonsdale street., it;s something like 16:80 all you can eat.
get there about 11:45 for all the best stuff to come out.
So...talk to pedders about the car.
first time suspension looked at since:
go over the whole car..no bent arms, bushes fine, mounts ok..
only thing they could find was some stiffness on the pillowballs from sitting 2 years so they ust cleaning thema nd will be ok..
Tire Bundles rock.
  • Like 1
Watching If You Are The One and a dude just rocked up with a gift (as most do)... But he brought a document of his life insurance in his favourite girls name, so she could sign it and become the beneficiary of 150,000 yuan incase of death. Wtf
Even if he is an insurance salesman... People are delusional
Tire Bundles rock.
Lucky the GoPro was on the other side of the car. Could have lost some money there.
  • Like 1
Looks like around 30 blocks sold already, people there constantly, don't think they're struggling
Yeah work off the highest advertised price for same size bank will knock it down if they need to but for re finance they always over value - if they think you can cover it Edited by alr33x
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
