The world will slowly but surely gravitate towards the dystopian future depicted in Equilibrium...tis only a matter of time and the reason we won't be scared of it is because it'll be such a slow, drawn out process.
The scary thing is that that movie is less a vision of a potential future and more an analogy of what we already do as a society - popping pills to keep emotions in check, censoring art and opinion, restricting choice and seeking out and destroying anything that threatens this.
/orwellianparanoid
Am curious if multinational organisation would sue poverty stricken child with Facebook provided internet access out of principle
FB armchair / feel good activists en masse
"The IP addresses identified belonged to those who “seeded” the movie"
If you seed shit you deserve everything you get
Define seed though....
Is that for while you are downloading or only if you don't stop it afterwards?
Seeding vs Leeching is only a term to distinguish between connected and sharing pieces, and connected to the tracker with 100% of the pieces...
You're guilty the moment you connect to the tracker, because you can't connect without SOME of the file (included in the initial .torrent file)
That's what i mean. I could download a movie and stop my client/delete the file the second it is finished and they could still say i seeded it...
Or do they look into if further and focus on people who seed long term?
But aren't you seeding while you're downloading? Hence the uploads. Or is that defined as a different term?
It may, or may not though.
Seeders, in general would have 100% of the file, and are sharing 100% of the file, and you could arguably identify and say that you're illegally providing/distributing the file for others, once you have 100% of an item.
It makes it a bit easier to go after seeders, legally, due to that.
Yeah, but you are always seeding when you have 100% of a file... even if it's just for 1 second before you stop it.
my point is will they go after THOSE people...
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
