lol . People want to see unique cars or people who are enthusiastic about cars or their car.
Even at pulsar meets, I can't stand those who turn up with a jdm sticker and weathershields saying it's just a P player car until they get a GTR.
Lettuce speak real tea here though, you never aspired the Pulsar as your dream ultimate car. All of these kids buy an interim car until they can afford their dream car.... like a Pulsar! They know not to polish turds ;)
  • Like 1
I used to be obsessed with Porsches. Then I realised modifying cars could unleash a lot of potential on more affordable cars.
Then I met supercar owners, Porsche owners and gtr owners. And thought f**k that shit.
:P nah most are ok. But $50,000 doesn't get you much of a Porsche, you could do a lot of with a POS and it would probably be twice the car. Like the micra. Heaps of personality and fun.
  • Like 1
Loved all the comments on fb about how it's unfair pricing people out of the market ... yerh cos you got outbid on a $25million apartment :/
inb4 Pat offered 24 mil
  • Like 1
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
