Great way to decrease Piracy...
http://www.news.com.au/finance/economy/so-called-netflix-tax-to-extend-gst-reach-to-online-downloads/story-fn84fgcm-1227298162874
up the cost of all streaming services.
why does one think they bringing this in as torrents will be dropping dramatically shortly.
So many feels
I wonder how long he will be there for, gonna be so many people there
Appearance at 2pm & apparently hoping he will stay to the end (5pm) as he is presenting the winners prizes
I miss the greek fish and chip shop back when I was growing up... Best everything, and would always throw in a bunch of free potato cakes etc, like we literally started ordering less items on the phone order, because we knew we'd get free stuff.
just to buck the trend....
My local F&C used to be Greek run and was taken over by Chinee about 18 months ago....
since then, the Fish is always fresh, the chips ALWAYS perfect and I always get extra potato cakes.
Indians making pizza is like Chinese making charcoal chicken, which is like Australians making Japanese and Russians making tapas...it just doesn't work.
Local chicken shop is asians foods amazing
Jus sayin
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
