Haha nah, a place in North Melbourne that my dad goes to
I don't think many of the clients there have ever seen a spanner before, he was shocked when I said I'd source/fit the stuff myself
Your pastel coloured suit probably threw him off.
Toby how you finding the evo 10? did you look at the sti as well?
Evo 10 as a daily is good. Comfortable and fast. I'd say faster than the skyline on the street. SST option is great, gear changes in a blink of an eye. Traction everywhere in all conditions. I got $60 china linglong tyres on the car and still got more traction than ad08's in the skyline
Only downside i think is petrol consumption and turning circle
I wouldnt get it as a weekend car though
I spent all my Qantas points on a Targus stylus
That's how much I see myself flying with them
Which might change in the future because virgin have really been dropping the ball lately
I love being in South Melb.
around 40 cafes/food places within 3 blocks plus the St Melb market.
plus I can park on the street all day.
moving to St Kilda road is going to hurt sooo bad.
Nah, I'm still in the same building.
I love working in docklands, our buildings are pimp
I love working in Footscray.
#saidnooneeva
Haha.
Fair enough.
Try these guys next time if it isn't out of your way:
http://activemotorwerke.com.au/
I have had many positive dealings with them with BMWs, GTRs and my Rangey. They charge reasonably and are professionals.
Haha.
Fair enough.
Thanks mate, will do :)
12 man firing squad seems excessive. Can't they just inject them with something?
This... Also with only 3 having live ammo to protect the executioners from knowing whether they fired a fatal bullet.
I'm pretty sure the callibre of marksman they use would be able to tell if he fired a blank or a real bullet..
In America it's all but 1 with a live round... far more logical
Less excessive than the transfer was... that's for sure
VWL, need opinions on muffler tips:
was originally going to go hidden 3" dumpy tip to keep it quiet and subtle, hidden behind the bumper. similar to stock (but less obvious):
but saw this picture and now almost persuaded to do the same. though not sure if would go well with stock bumper style. +5 bippu points, but not very subtle
they army shooters, don;t credit them with being marksman.
we used to have army folks come to our shooting days and walk away shaking their heads.
the targets they aimed at at 75 meters were same size as the ones we were using a 1000 yards (900ish meters)
but yes very easy to tell difference between a live and blank.
they are like 5 metres away lol
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
