How much was the tomei one?
Got it from Miguelone during his "I no longer have a skyline" clearance sale... Can't remember, but it was definately more than just the sentimental value...
iirc it was around break even price.
Unlikely to find another. Not that I've been looking recently but when I was collecting all the green anodized Tomei bits it's the only one that I didn't see come up at all.
How was it?
well it ended up at 17 courses..so that was a bit over kill.
every item was amazing on its own, but so many strong flavors started blending in with each others.
less courses with a cleanser would have been a bit easier.
the whisk gums at the end were out of this world however, only had tried 2 in real life and tasted exactly correct.
11262211_10207066817211758_7451064058628
they call it a once in a lifetime event, and I can see why, more than that and you would die of a weird combo of heart attack and gout..
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
