As someone more inclined to drink them you really should have more
Really fighting temptation to crack one open
I literally bought a chivas 12 to stop me opening the green... i have already had 2 glasses.
I give it till the weekend
Cctv footage of evo car thieves on youtoob.... No number plates (but guaranteed to be stolen) and also a latest model corrola, just like the photos from a recent supra theft in a multi storey car park.
Hi. :action-smiley-069:
Short time poster, Long time lurker.... and your friendly local club secretary.
Membership prices are increasing by $10 each as of midnight 4th July - so if you want to renew, do it now! Just for the member priority entry to SAU NATS if nothing else (which by the way will be in sunny Victoria this year)
Thread with details in the Vic section. :yes:
you have 6 bottles why would you not open one??
what the hell else are you going to do with them.
I have 7 and I'll eventually drink one - rest will be sold for profits or given out as special presents
Shit is like dragonballs
  • Like 1
I've never seen the point in buying shit with the intention of selling it for a profit, if the amount isn't life changing...
Do it enough times in life and it is, good pocket money at least but then we ain't all on dem overtime rates
What I like is that I could sell 3 bottles and the remaining will be paid for so it's almost free goods, just a small amount of effort. Give it long enough and 1 bottle can pay for the remaining 6
But then you got honest, hardworking blokes, like Ric & I, looking to wet our whistles after a long day of business but can't find a single bottle for sale cause Birds cleaned out the store. :(
The struggle is real.
I probably wont sell any. I just love green label
Fuel pump changed - so damn quiet now. 040 bliss
Surprisingly the part that should have been easy; pulling the plastic retaining collar off, was a prick and required a $40 wrench (no getting that off by hand - still needed a heap of force on my long ratchet). And the part that took me 2 hours last time I changed the pump; trying to hook the fkin pump arm onto the bracket, was done in about 5 minutes.
Fuel hoses in the tank were splitting near the hose clamps, within the nipple and still airtight so should be okay, but might need a longer term solution for that. Alas Pirtek aren't open at 9pm.
Hamish what was that restaurant you used to work at when I picked up a stock r33 steering wheel off you? would you recommend for a dinner date?
Cosi, Couldn't recommend due to new ownership.
The new owner's other restaurant is pretty decent though - La Cita
how much you wanna spend per head inc drinks and how fancy?
Just looking for something around the south yarra area, not sure maybe <40 a head
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
