the mona lisa lol
The first thing I want you to do is rip that e brake
The only reason the evos pop on e85, is because tuners like to cram timing in downlow.. The rods can't handle to much low end torque..
Burnzy has said out of all the 7's he has tuned on e85 only one popped, because of something completely different.. Ie waste gate or something
Yeah fair enough, good thing I'm going 8+ and I'll probably get burnzy tune as well. But i thought we were talking about injectors fouling due to e85 not tune pushing out too much torque low down especially during search for power wheh e85 tune
Yeh. That's the main reason they blow if they have injector upgrades..
If not. It's because they are of the retard kind and expect stock injectors to flow enough for r85
Think youll need bigger sprinklers, dont quote me on it though, could be wrong.
He'll be find. Won't be pushing anymore than 250 with an RB20, he could just about get away with S15s for it.
Dat 2.0
he'll probably only use 4 tho
so i dropped my phone at work and didnt realise. find it bent like a f**king banana and crushed.
worker ran it over with the fork and didnt notice.
f**k.
also, sam greco came in yesterday.
actor from fat pizza, swift n shift and underbelly
also seems to f**k people up.
See him every Tuesday..knew he was from those shows but never knew his name... nice bloke
What brand?
I made it to 330rwkw at 92% duty on nismo 555cc
but most people have run out of flow much lower (thinking nismo 555's are just the 740's painted a different coulour)
Cheers
They are SARS injectors. Rated 550cc. Had them flow checked. Came back 570cc reading
Smashed taco's for lunch. Was amazing.
I love the flavouring on Salsas chips :yes:
Monosodium glutamate, also known as sodium glutamate or MSG, is the sodium salt of glutamic acid, one of the most abundant naturally occurring non-essential amino acids.[1] It was classified by the U.S. Food and Drug Administration as generally recognized as safe (GRAS) and by the European Union as a food additive. MSG has the HS code 29224220 and the E number E621.[2] The glutamate of MSG confers the same umami taste of glutamate from other foods, being chemically identical.[3] Industrial food manufacturers market and use MSG as a flavor enhancer because it balances, blends and rounds the total perception of other tastes.[4][5] Trade names of monosodium glutamate include Ac'cent, Aji-No-Moto, and Vetsin.
Not confidence inspiring...
But dat e85...
why wouldnt they upgrade the injectors and pump if going to e85.. trusting 12 year old injectors is obviously not the smartest thing to do.. lol
You misunderstood, this was with upgraded 1000+ injectors and fuel pumps
give it to me immediately
cost moneh
The best part was ignoring the S15 they could have used instead...
The Mona Lisa if you will...
Also re: the e85 evos, I thought he meant that was happening WITH upgraded 1000cc+ injectors and fuel pump.
Yep, not on standard injectors/pump
your an idiot, I'm talking about e85 destroying the insides of the injectors and making them run lean
Everyone knows about the late modelled 6.5 and 7 weak rods
Who cares about Evos anyway, we were talking Skylines and E85. You Evo boys take your 4 cylinder garbage out of here. Only milk and juice should come in 2 litres blah blah get out my country.
Guest
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
