yeah... although there is literally no passenger seat left... the pole went right through and is where the drives seat should be.
I can see him walking unfortunately :/
Coupes are more expensive yes. I completely forgot about getting some prices for you. Sorry man. Will check in the morning and let you know
I thought the same sedans look heaps better
Sweet no real rush not like I'll be buying next week anyway but send em over whenever you get a chance so I know if I'm dreaming or not...
Sedan it is.
The only reason why I say not with instructor is because of price. They usually charge 1 hour lesson beforehand + vicroads, so $220 all up
It's pricey but so are retests...I considered it insurance at the time. My instructor and the tester were old mates and the instructor was telling me he hoped we would get him haha.
So yeah, in short, I shouldn't be on the road.
F6 310 or FQ 340
e8MR or e9
with almost no money spent is quicker AND more responsive than FQ
and F6 depends on how much you want to mod
my 7, the money has already been spent. its clean and rust free, aaron also checked it out when it was forsale in vic.
http://www.skylinesaustralia.com/forums/topic/436461-2001-mitsubishi-evolution-7-249kw-on-98/
Abz, I don't think they'd fail you straight away but depending on the square you get maybe they'll be a bit prejudiced / tighter for it...
I just used my mates impreza (just an rs) for the test lol
Cheers for the advice brahs!! :) Yeah got done for driving manual on auto licence so going for the test this friday. RACV peeps all on holiday so imma try someone else tomorrow but other than that i'll just take my mates accord euro, no point going through all the hastle in the skyline plus scraping at vicroads lol.
remember to double clutch and not granny shift
but he no buy, so not good enough?
Who was the bloke that tried to sell me a set of tri spokes that isn't Niroj or Mike a while back?
It was white late model tris in 17s from memory?
I want white tris now. Halp?
Guest
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
