Have read in a few places that if there's finance owing on it, isn't the general procedure to get a printout of the remaining owing on it... then YOU pay the finance company with one bank cheque, and pay the seller the remaining balance?
Seems better than trusting a seller you barely know with your money until they pay off their debts and still have the car...
Bought a car tonight.
If the seller pays off the finance tomorrow, how long before I can get confirmation that it's unencumbered?
That's not how you announce something in Vic wasteland
You're supposed to write like we already knew about it
  • Like 1
Sup yo...
Recommendations of Paint Strippers which are strong as fk and would be able to munch up factory powdercoat from alloy rims?
Would bunnings spec be good enough? Just aim for the one with the most lethal sounding warnings on the label?
Getting tyres / weights / valves stripped off my rims today so I can spend the night getting dirty and prepping them for some sweet satin black paint action.
where can i buy some 600mm long condoms?
need to water proof some zuchinis for international export.
#subtle.
  • Like 1
Best stripper can be bought at SCA and is an orange/red lava colour.
Stings the moment it contacts, no delayed burn like some. Rancid smell too, really gets up your nose.
I did end up getting the Polystrippa pictured and it works well... Used a wire wheel to scuff
Paint just falls off the shiny metal underneath... Does want to still grab the spokes which are all sandblasted judging by the texture underneath, but still comes off fine with a few coats and some hard sprays with the hose (don't have a pressure sprayer with me atm)
Now, where can I buy paint from tomorrow to spray these satin black with a semi-gloss finish?
Guest
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
