I did end up getting the Polystrippa pictured and it works well... Used a wire wheel to scuff
Paint just falls off the shiny metal underneath... Does want to still grab the spokes which are all sandblasted judging by the texture underneath, but still comes off fine with a few coats and some hard sprays with the hose (don't have a pressure sprayer with me atm)
Now, where can I buy paint from tomorrow to spray these satin black with a semi-gloss finish?
You already know the answer to that question why are you asking you weirdo.
Went for the msi gs60 ghost pro 3k. Better not be shit, kunce
30 day return policy as long as you can wipe all traces of your sleeve tatted beefcake jizz off the keyboard.
wait.. wut? wasn't the 3k model like $200 over your budget?
I didn't really have a budget, but wasn't going to spend $5k on a laptop when I'm not even gonna use it for what it can do (gaming)
But I don't like buying inferior products either, so I said a number to give you guys a range to work within..
I got it for $2550 from centercom in the end... scorptec wouldn't go below the ticket price of $2649, online stores I could've got it for $2400-$2450 but I wanted to buy it in store..
Depends what type of investment property you looking at. Negative geared or positive geared.
Are you planning on capital growth (with low rental yield) or high rental yield with low capital growth.
I have no idea. whatever makes me money.
Both can make you money just differently.
Capital growth gives you a big payout (minus capital gains tax) if the property shoots up in value.
Whereas high rental yield will pay off the mortgage repayment allowing you to borrow against it for another property etc. if the rentals are paying themselves off, eventually you'll have a steady stream of rental income trickling through as profit.
Guest
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
