the annoying thing about jewellery is that they can charge whatever the f**k they want for something and make up whatever bullshit, and 95% of everyone dont know any different.
Yep. Bought a ring for 4 grand (got $200 discount) 2 weeks later the same ring was on sale for 2 grand.
thus why you get an independent valuation of the stone..
got the GIA (http://en.wikipedia.org/wiki/Gemological_Institute_of_America) prior to purchasing the stone.
valuation came in about 5-6K more than payed for it.
the jeweler discounted massively if you get him to make one, as he knows it not going to sit in the window for 12 months wasting him money and maybe need a redesign or be in a sale.
first time ever custom cheaper than off the shelf
pretty happy all in all.
Rebuilt engine.
+5kw, 500rpm earlier response... 10 degrees less timing... and 10 PSI less boost.
I should immediately put car up for sale
But I won't, because it would feel wrong for anyone else to break it
  • Like 1
Rebuilt engine.
Ummm did you run it in? Same turbo?
...10psi goddamn
Rebuilt engine.
Obviously forgot to rebuild your head...
Sell it!
Rebuilt engine.
Good work, post up dyno graph?
Is the engine still being 'choked' by the turbro?
guys, sometimes i dont understand how f**king stupid some people can be.
im in the office doing some quotes, all the doors are closed, gates are locked shut.
dude just rocked up.
called the lane line- no answer, called me, no answer. then tried to push the gate open.....
omg this shit makes my hair hurt.
I can't actually post up the dyno graph because it kills Trent's dyno when trying to do a proper pull.
I'll have to try it on a roller dyno ;)
But I would like to confirm, cause if someone on the forums said they made 408kw (in a manual) at 21 psi (the dyno's gauge) on a GTX3076, with 225rwkw at 3000rpm you would quite rightly think u f**kin w0t m8? And laugh them off the forums.
(yes I ran the engine in beforehand.. my life is empty and I can afford to do 1300run in kms during the week)
Tony coming to Sandown day?
Probably not, my engine isn't where its supposed to be atm
11112218_1049642438383448_26285725279759
Haha yeah hard about that!
Nah dont doubt your power figures, just curious what its like up top if its still like your previous graph, kinda showing that you have a turbo restriction.
But then again bigger turbo and youll have a million killer wasps which you probably dont want!
Guest
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
