haha this needs one of those meme's seen a couple pages back. Havent seen one for Engineer yet :P
I worked at a supermarket between highschool/uni break, pissed off after end of first semester to a better job. Shit pay & long hours.
Managers in any business need to learn to show respect to people and to do this is to unlock the maximum potential of the employee.
By paying people to only do one task is implying that you are only capable of doing one thing and is a sign of disrespect. No wonder the same attitude is displayed back to the company...
my tip; look for a casual job which utilizes your capability you will be happier off.
Good points there Pat!
Very true too.
Was just implying Alvin should do something in his field of study, hence Engineering.
Hey Bluejeans!
Saw your car and thought I'd buy 5 of them!
Damn, I miss mine :(
When I get back, imma trying to get another one, hopefully 300+ kw.
i've yet to graduate..
but i'm considering starting up a hotpot restaurant..
I see, let me know about the hotpot restaurant.
I am looking into expansion / investments... More so scoping out opportunities.
yeah, that's one of the cheapest startups.
and with so many azns. i'm sick of the hotpot places run by the prcs... they're crap.
Yeah, what's with that? Way to stuff with the OCDs!
Gixxers are nice.. I find the thousands handle far nicer than the 600/750 though.. Both are hawt. New 600/750 not so much. New thousand yes please.
Something about the new gixxers just doesn't look right....Front headlight too big or something...
My mate has a k7 or k8 600...looks the goods. Think that's what I'll be getting but a 750
Agreed. Actually, late model gixxers on the whole I'm not a fan of the headlights. They just look too busy and dorky, doesn't seem to fit with the rest of the bike's lines.
Mates R32 gtst got broken into last night, little rats stole some change, his paintball gear, pod filter and boost gauge. Why would you break into someones car to only make off with a) shit you cant use and b) stuff only worth like $20
Guest
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
