  • Replies 742
New suspension is amazing. Was carrying a lot more speed through 3 and hayshed (both around 200km/hr through the middle now which is significantly faster than before).
I had a lot more confidence in what the car was doing mid corner to what it was like previous.
It was a good thing but still needs a few tweaks. Was a bit lose under brakes from big stops - but especially interesting into turn 1 and between 11 and 12! :) New wing going on Monday might help that though.
I may have done a 1.43.8 too.
Is anyone going to be posting Vids in here?
Unfortunately I'm out of the country while its on, and after going last year, I'd really love to see some footage from this year.
The website had live timing too I think last year, yeah?
Could have a wet track at times going of the forecast, also the wind speed is high...
Should make for some good driving to watch
http://www.weatherzo...y/eastern-creek
unfortunately that will only mean even less running for the big guns - no point wasting tyres (and the car!) on a wet or damp track...
If it does rain, pray it rains all weekend and you'll see a mad dash on Saturday for the top guns trying to put in one fast lap in the afternoon. Could get quite interesting if they're not used to the circuit in the wet.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
