So I have slapped on some hard compund Hankook Ventus TD Z221 for Phillip Island. I also have a set of 295/35/18 AO50s but think I am in for all sorts of trouble to get them to fit my car.
Has anyone fitted the 295 AO50s onto a 9.5" rim ? Or do they really need a 10" rim?
Looking for semis for my GTR. Essentially want something that is going to last a few track days but won't take forever to heat up. Also, the cheaper the better :)
I have yet to buy rims yet but I was looking at 18x10, so would 265/35 be the best profile? I am not finding many semis in that size. Should I look at other rim/tyre width combinations?
Need to fit V8 supercar alcons underneath.
Cheers
Cheers
I'm in the same boat as you except my rims are 18x9.5. I've found a fair few tyres that would be fine but I can't afford them at the moment so I just started snapping up the used 265/35/18's off ebay.
I might start off with that as I don't think I'll be getting the full potential of new semis just yet. How do you find the used tyres? What do you look for when buying them?
Ahem - surprised no one has snapped these up yet:
http://www.skylinesaustralia.com/forums/topic/423228-syd-28530-18-dunlop-dz03g-sparco-slalom-sl-3-racing-boot/
And I have 295 30 18 A050's on 18 x 10's. Seem just fine and fit under the guards of my 33 GTR - hint hint Fatz.
I have 245/35 on my 18x9.5's at them moment and they are stretched hence the step up to 265's.
I just put 265 18 into ebay or semi slick and see what comes up. I picked some up earlier this week and now i'm just waiting till some more come up at a decent price.
No clearance or rubbing issues with 295's Eric?
I have a brand new set of R888's at home in 265/35/18 but am considering snapping up a set of 295's I have access to instead, and was wondering how they would be on an 18 x 10.5 rim.
  • 2 months later...
Need your opinions guys...for the same money...would you choose:
1) Toyo R888s 275/40/17
or
2) Hankook Z221 255/40/17
Tyres are going on 17x9.5" rims front and rear...are the Toyos really as bad as people make them out to be?
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
