lol sigh. you guys are no help.
why not just take advantage of the hot-cold pressure drop then? Get a low pressure atomising nozzle and run boost from the comp housing into an air tight tank with the other side plumbed just before the TB with a check valve.
get it together for $20 bucks, could even pick up a set of steak knives within the budget if you wanted.
but wait, theres more.
^^ classic stuff boys
done a little search today and read up one the same thing stated, a metal sealed tank and run line from boost source to pressure tank then connect pipe before th/b, cant hurt right ?
might get those steak knifes after all too..... lol
It needs to be atomised to the max, and I'm afraid that 20psi or there abouts isn't going to cut it.
My setup had a 150psi pump, and the new setups have a 200psi pump.
Have you seen the output of the nozzle at that pressure? It's like steam. 20psi woulda make it dribble and be useless for proper atomisation.
What you are trying to do is re-invent a system that has already been tested and design proven before.
If you do want to spend time wasting your time and money, and potentially destroy your engine, then I guess that's your choice.
You can get an atomizer that will run at very low pressure but the benefits will be minimal at best.
Mafia is right that the kits come with big pressure pumps, but im not sure if they opperate at that sort of pressure continuously.
You can easily do an effective pre turbo WI setup the way I described. Boost pushing through an atomizer before the turbo.
You will need a ball and spring like a turbotech to prevent boost getting through before target pressure though. Otherwise you will get a trickle of droplets coming through before you hit target boost pressure. This will work and has been done before.
When to tank releases the pressure it will drop down but due to the small hose/line trying to fill it it will not repressurize or hold a standard pressure.
  • 4 weeks later...
So I got the snow performance kit stage 2
Just saving some money and then going to drop by and get JEZ to have a crack at it.
Few questions.
Can I run this without a tune and be safe for the time being if I decided to install it?
What nozzle should I be using on a 270-300kw setup?
What boost should I be starting it at if I am maxing 20-21psi?
Cheers guys :)
Be fine without a tune, i have run from 100cc through to 340cc on a my stockish stagea..goes best with 100cc(because its untuned, and makes f**kall power.., even on 40 degree
day goes like a cool night.
What jets do you have, or have available?, around 250-300cc would be in ballpark..probally the lower number , start at 7-8 psi ish.
I just fitted a pre turbo rice racing atomiser to my mates vl the other day. It runs 10.4@133mph on a 98 /10 percent meth mix, but suffers
heatsoak and melt plugs from det..either from tune or heatsoak related tune issue . Anyway fitted kit, took it out to a powercruise style event for the day, ended running 450cc(straight water), no bog with
CDi ignition..28psi of boost.
Plugs stayed killer...
before it was melting of the electrodes clean of at bottom of plug..not sure how the motors survived this long really .
With retune and new camshaft and maybe more boost should be good..
Also no heatsoak in intake..nice and cool...before you coudn't touch it..
cheers
darren
Edited by jet_r31
So it wouldnt cause issues such as leaning out higher in the rev range due to more power being made?
The tune of course isnt on the edge but just wanted to make sure.
The lowest boost I can run is 20psi
So thinking of just strapping the kit on and start boost at 8psi all the way through.
Also just using straight water until we go to tune it.
It won't/can't run leaner simply because you're introducing a water mist into the inlet airstream.
That can/will only happen if you adjust the ECU and reduce the injector duty cycle at each rev/load point.
You should find that best results actually come from leaning off the fuel and increasing the advance.
To start with I'd suggest a good starting point is the 8-10psi mark, and ramp up the WI pump duty so it's hitting maximum around 16-18psi.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
