2 minutes ago, BakemonoRicer said:
legendary mods.
all thats left is to fkn stance it out m8
stance it m8
Be happy to have a starter motor that works.
Needs a wheel alignment. Rear left wheel is ordinary lol
1 hour ago, Sync said:
I asked and Scott didn't want to. I'm sure the is a reason for it. I suppose in theory there shouldn't be much of any difference between each scroll.
I wanted to put one on out of curiosity. Down the line with a larger snail (9180/1.05) and possibly a 1.45 ass end to see what difference it makes to the exhaling with ease. Definitely not "needed", it was more of "bugger it, while the manifold is off" thing.
I REALLY wish I had it while the twin butt plugs were on the car. It would have been halarious ?.
Turbine speed is critical if you're gonna push these things. It's no secret they have a limitation and there is no way of knowing without a speed sensor. Boost means jack shit.
  • Like 1
Fair enough, turbine speed I was across, just wasn't sure what the need for EG pressure was other than data logging.
More info the better I say.
Too much guesswork on these forums.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
