Fugged if I know.
I dropped in there yesterday and asked what's going on as they are listed as having E85 on the website. There were two guys behind the counter, one stared blankly at me, the other clearly knew what I was talking about. The knowing one said they dug up the forecourt (which you could see) to install the required lines but then figured out that the tanks were fibreglass and therefore unsuitable for E85.
Would be interesting to hear from someone in the know. I assume the alcohol and fibreglass resin probably do not get along too well? Anyone know the chemical reason (assuming that is the reason) why there is a problem with putting ethanol into FG tanks?
Whats wring with fibreglass tanks? All new caltex sites are getting fibreglass tanks to replace the old steelies
The issue is that under normal circumstances, fibreglass is resistant to ethanol but not proofed. So over time, your average fibreglass fuel tank will dissolve with ethanol. But fibreglass tanks that are designed for use with ethanol are lined with a special resin that proofs them against ethanol.
So the new tanks will be suitable as they will be designed for it, the old tanks that are already in place will not.
I think most cars from other turners don't have AFR's that rich because they don't believe it's needed. I know we sure don't have a need to tune that rich and don't have issues (very long and healthy life motors), but if it works for you then all power to you.
2 things........ If the engine doesnt need 10.5:1 then it wouldnt get it. Tempretures are the decided of this one. You should probalby shoot Nissan, or ford, or toyota an email and tell their engineers that they have had it worng for years and they are wasting valuable fuel in the search of reliability.
Also your idea of high power and dans idea of high power are probably 2 differnt things.
In your case, with a single 044 running the show, your tuner probably has no choice.
I'm also referring to cars that actually do fast 1/4 mile times. They are the ones that matter
What are your EGT's?
Just put in a Walbro E85 pump, still only going to run 11.6-11.8 :)
oooo and Ethanol thread... cool :)
here's my write up of my E adventures... and looking at the date, it's been a whole year already!
E85/98 Flex-Fuel Mission Complete! Thanks To Chequered Tuning!
Yeah.... Fly your flag more! haha
Most of these engines need 10.5:1 AFR as they come up to peak torque but seldom do we ever see that when cars come from other tuners......and that's why the engines that Sean tunes for us live a very long and healthy life.
My current tune is on the richer side (mid/high 10s) at full load. Keeps EGTs on the cooler side and is a nice buffer when making stupid power.
Ok..... I missed something....... and this is very important.
Lambda:1 for E85 is important how every there is a small miss conception about how AFR meters actually read the air and fuel ratio.
Now when all the oxygen is burnt in the combustion chamber and there are no hydrocarbons (raw fuel) left this is lambda 1 for any fuel.
Oxy sensors read in lambda not air fuel ratio.
Now we all know Lambda 1 for 98 octane is 14.55-14.80:1 depending on composition of the fuel and what additives are in it on that day.
Regardless of the AFR you 02 will always read in lambda.
Now, your AFR meter will convert Lambda to what ever calculation you put into it. So if you say that lambda 1 should display 9.76:1 then it will.
An easy way to explain it is to show what happens if you change from 98 octane to methanol on the same tune.....
Tune an engine to 14.7:1 (lambda 1) on a dyno for 98 octane.
Drain the tank, fill with methanol
Start engine...... now the engine will be super lean because Lambda 1 for methanol 6.4:1
So you add more fuel to your tune.... and what do you know...... 14.7 (petrol) on the dyno is still lambda 1 regardless of fuel type because that's what the sensor reads in but will still display 14.7 on the dyno because that's what you have told it.
  • 3 weeks later...
  • 1 month later...
Brand new United just opened on Yan Yeah Rd in Doreen....and it has E85!
Booyah! E85 5 minutes from my house :)
Happy days! Now it's a matter or saving the pennies for a HG and 1000cc injectors and I'm good to go.
a question for the tuners or those in the know,
is it possible to have an e85 tune that consumes fuel the same as running 98 yet makes power the same as running on 98 fuel, for example not tuning for max power on e85 yet priority no.1 is fuel consumption
and power results match up to 98 fuel on max a power tune ?
reason i ask is some people with smaller fuel tanks( 40L ke70's etc) and those that want their fuel to last just as long as 98 dont opt for the e85 route
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
