4 hours ago, Dose Pipe Sutututu said:
Is this your car?
https://www.gumtree.com.au/s-ad/wahroonga/cars-vans-utes/2002-nissan-s15-200sx/1251512935
I guess I was wrong with the Samsonas and the power, but 506kW was close enough.
506kW..."Never thrashed or abused" LOL
$75,000... double LOL
  • Haha 1
It’s running. Starter motor was buggered, new one has been installed and a new TPS also.
Dyno on Friday I’m dropping off 100L of fuel tomorrow and 3 canisters of NOS , gonna need a 200 shot to make the numbers
6 minutes ago, acsplit said:
Scott's Dyno magically kills starter motors.
*Looks at the emtron fanboy with his gtr*
& Racepace kills motors, pls.
Emtron is #1, move over Motec there is a new playa in town.
Once i started boasting about them online years ago before I even ran one everyone followed.
3 minutes ago, r32-25t said:
That’s the only thing you seem to be able to fault with the haltech and yet the best engine management system in the world uses multiple boxes
Yeah I can't fault them for forgetting tunes. Oh wait yes I can... Multiple times actually ?
Edited by Mick_o
1 minute ago, r32-25t said:
Oh the vcam tune it forgot that turned out to actually be an issue with the vcam itself
No there was more to it than that. And that was only 1 incident. There were a few attempts to add new firmware patches etc prior. Luckily his coils weren't fried when adding said firmware updates...
  • Haha 1
Like how all Ecus should have the coils and injectors disconnected when setting it up?
  • Confused 1
Just now, BakemonoRicer said:
Haltechs aren’t even worthy of being put in Silvia’s honestly. They are the power fcs of today’s ECUs, if you’re a big hitter you obviously run emtron
If you’re a bigger hitter you run MoTeC
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
