I've always thought this would be an amazing conversion. Insanely good engine.
Huge amount of work though, predominantly in getting the sump right.
One positive is that they both have an alloy sump so grafting one to the other is theoretically possible.
Huge amount of work though presumably.....
Just do it and we'll all know!
You like the handling, but what is the weight difference between the ford engine and the RB, and how much further will it stick out past the front wheels?
The RB is 15 kgs heavier than the xr motor. That is comparing long engines.
  • 5 years later...
People say the RB26 looks like a matchbox partially tilted sideways and doesn’t look to powerful compared to larger Ford and Holden engines but there’s something about it that I just adore and love!
Never heard anyone say that
On 10/11/2018 at 5:37 PM, Robocop2310 said:
Barra-Zilla?
Does have a ring to it but personally I like the RB26DETT more as it has more low end torque she sounds much better too.
RB26 has so much torque, like -180nm at 2000rpm than a Golf R
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
