Sounds good!  Glad to hear you're happy with yours.
I liked the design of the Sinco over the 6Boost the way they run full split wastegates (one pipe off each half of the manifold then merging into one and even once merged it's still split all the way to the wastegate valve face.  Shouldn't lose any of the split pulse benefits that way.
I have zero doubt that the 6Boost would still do an amazing job but decided to go this way for something a bit different!
Same reason why I went with Sinco, because it's a true twin scroll manifold not like the 6Boost ones or similar.
So much Sinco love ??? ha ha!
The flanges are super solid,  5 year no crack warranty,  can't go wrong!
I must say I do rate you sheep shaggers as great fabricators! Rob from Racefab in NZ made my extended sump which is also a great piece of workmanship.
Some very talented and alternate thinking guys there.
While I'm throwing out the compliments  it's a bloody beautiful country. If anyone reading this (all 3 of you ??) hasn't been then get your arse over there, it's stunning at every angle. Queenstown is one of my favourite parts of the world.
Right, enough love, time for an NZ joke to square things up...
  • Like 1
Been to NZ twice already, great place - but one mofo who walked past us at Ferg Burger and made a snide remark "Oh looks like China is here" (I'm Asian but born here), so I stood up and and said asked politely "what the f did you just say?" and walked towards him. His mates were smart and dragged him away.
Other than that, pretty good experiences both times.
A few of your regular readers are kiwis...
There are dickheads in every country and NZ is no exception
Hell yeah, I love it!
I told the missus I was going to hang it on the wall in the living room for a few months as a work of art.
Strangely enough she wasn't convinced.
My 6 year old daughter told me "that's not art daddy, that's ugly"!  Ha ha, bloody kids!
  • Like 1
9 hours ago, Shoota_77 said:
Ooooooo mummy....
Just mocking it all up for now to work out how much of a nightmare the exhaust is going to be....
... annnnd I'm done :o
Turbo, manifold and block are probably similar enough to this to get some ideas:
I read that post @Lithium but I didn't realise he was running Sinco too. Should be quite similar in design. I probably wasn't going to go that far back to bring the waste gate pipe back into the exhaust. Is there a preferable distance back from the turbo that works any better? I was probably thinking of bringing it back in at the bottom bend something like this-
Yeah, definitely Sinco and I'd say the same design - just for an RB25 NVCS head instead, and different coating.  Works really well.
In all honestly without having hard data etc I won't stamp my foot down with any strong opinion on the merge location, with gas flow where possible I like the idea of not stacking up too many "events" which can cause turbulence at one point as that can increase drag and slow down flow - both a bend and also a merge are sources of turbulence, so I guess at that bend there could be quite a bit happening compared to if the gases just have to take a bend then have a merge after the  fact but really I have no idea if or what the significance of that is... or if there are other things which could compromise spreading it out like how the sedan has it.
For what it's worth, the sedan is running a .4bar spring and experiences slight boost creep after a decent pull on wastegate boost - reaching maybe 8-9psi at full rpm if given enough time to, but it can hold 10psi dead flat.   The setup certainly flows well, though.
Looks great but i think I'll be plumbing it back in as soon as possible while still following the basic principal of coming back in on a nice angle as opposed to at 90 degrees.
For some reason I read my very first page of this build page and below is one comment that stood out.
It's good that I know myself!  That was almost 7 years ago (December 2012) I wrote that.  I must have had crystal ball!!!  Either that or I'm just shit at finishing things off....
  • Like 1
Hey mate, cheers for that.  Your mate did a good job!  I'm an absolute TIG noob so will take me ages to do what probably took him not long at all!  There will be a lot of measuring, cutting and grinding and it still won't end up looking as good as yours!!
Doesn't matter, as long as it works and doesn't look like cocky shit I'll be happy enough!
Enjoy driving your beast, hopefully not too far away till I get to do the same with mine.
  • Like 1
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
