301rwkw at 20psi? :P
Sonofabitch! :P
Over 9000
Well trents dyno said 301kw but my scouter did say over 9000.
Sorry for the small photos but its all I have at the moment. I understand that stao is currently pulling my car apart in an attempt to fix my boost control issues, which are pretty obvious if you look at the dyno graph.
Hopefully get it sorted before this weekend as I am travelling down to pick it up. But Trent and Cat are absolutely fully booked out. Does anyone know of any other tuners in Melbourne that are open Saturdays? All the idle stuff is done and its tuned for that boost plot currently. Will just have to get someone who knows what they are doing with a greddy profec b spec 2 to sort out the boost control and do a power run to check the tune is still fine.
  • Like 1
Right. Well I'm drunk at the moment but picked up the 32 today and holy shit it's an angry car! Made 312kw@20psi and it goes like a shower of shit. Will give more detailed results tomorrow.
Also, pics. Because everyone likes pics.
  • 1 month later...
So, been a while since the last update.
Basically i have been doing minor things since getting it back from trent. Stereo, gauges, tidy up wiring etc. Have done 2 drift days and holy shit it is a different car to drive.
Second gear is useless and third gear is now where it's at. Still have power steering issues that i am yet to fix.
Basically i am stoked with it and just need to drive it more often haha. Will update thread with more info/pics if people are interested.
Yeah went in no worries man. The paint on them was shit and started flaking off but apart from that it is all sweet. And a bottle of jimmy is the least i could do for the run around that Brad gave you!
http://www.youtube.com/watch?v=SdRv1bXTv04
  • 3 weeks later...
^ just paste the address into the WYSIWYG editor and it will do the rest :)
Also, how are the lines holding up from Kando? Mine arrived yesterday, but those idiots at the dim sim factory sent the wrong crush washers LOL
Yeah, i made sure that i did everything possible to help them out. My mates Subaru liberty (which sits lower than my car) seemed to be fine, don't know how they managed to f**k mine up so bad.
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
