301rwkw at 20psi? :P
Sonofabitch! :P
Over 9000
Well trents dyno said 301kw but my scouter did say over 9000.
Sorry for the small photos but its all I have at the moment. I understand that stao is currently pulling my car apart in an attempt to fix my boost control issues, which are pretty obvious if you look at the dyno graph.
Hopefully get it sorted before this weekend as I am travelling down to pick it up. But Trent and Cat are absolutely fully booked out. Does anyone know of any other tuners in Melbourne that are open Saturdays? All the idle stuff is done and its tuned for that boost plot currently. Will just have to get someone who knows what they are doing with a greddy profec b spec 2 to sort out the boost control and do a power run to check the tune is still fine.
  • Like 1
Right. Well I'm drunk at the moment but picked up the 32 today and holy shit it's an angry car! Made 312kw@20psi and it goes like a shower of shit. Will give more detailed results tomorrow.
Also, pics. Because everyone likes pics.
  • 1 month later...
So, been a while since the last update.
Basically i have been doing minor things since getting it back from trent. Stereo, gauges, tidy up wiring etc. Have done 2 drift days and holy shit it is a different car to drive.
Second gear is useless and third gear is now where it's at. Still have power steering issues that i am yet to fix.
Basically i am stoked with it and just need to drive it more often haha. Will update thread with more info/pics if people are interested.
Yeah went in no worries man. The paint on them was shit and started flaking off but apart from that it is all sweet. And a bottle of jimmy is the least i could do for the run around that Brad gave you!
http://www.youtube.com/watch?v=SdRv1bXTv04
  • 3 weeks later...
^ just paste the address into the WYSIWYG editor and it will do the rest :)
Also, how are the lines holding up from Kando? Mine arrived yesterday, but those idiots at the dim sim factory sent the wrong crush washers LOL
Yeah, i made sure that i did everything possible to help them out. My mates Subaru liberty (which sits lower than my car) seemed to be fine, don't know how they managed to f**k mine up so bad.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
