So initial word back from GCG is that the core needs to be replaced in the HKS, housing seems to be ok
We'll get a phone call sometime this week to go pick it up
In the mean time, we went a bit crazy on a recent order with HiOctane for the 34......
So we have got:
Haltech ECU
Tomei Type-B Pon Cams
Tomei Cam Gears
Walbro in-tank fuel pump
850cc injectors and FPR
Upgrades gears for the oil pump
All this will go in after the track day in September, I want to get used to the new clutch first before putting more power in the car
We'll also be putting in a Gates timing belt and a new water pump while we are in there.
Also planing to get a Plazmaman plenum, throttle body and Billet fuel rail, paint the rocker covers and clean up the bay a bit
BRB while I start on my Mi Goreng diet lol
  • Like 3
I'm not too fussed on the wait for the extra power but my mates and mechanic have been pushing me to do the work now and not wait until after track day.
I could do it all now and it might be ready by track day (all depends on my tuner) but I will probably miss the 32 GTR 25th anniversary day cruise/lunch next month which I really want to take the 34 to
Having no boost for a month is a killer lol, it's an addiction. The longest I've gone without the car previously has been 2 weeks so this is a real test for me, it's like giving up smoking lol
I am interested in seeing how much power I will get out of her once everything is in and the HKS finally pushed its limits (only running at 50% at the moment)
Looks like a fun combination haha. My car should be ready in September too, maybe we should organise a cruise somewhere...
Nice, what are you getting done?
I'll be up for a cruise up until track day late September, need to rack up the k's on the new clutch, come October she'll most likely be off the road again for the work.
Same as yours but instead of cams I'm chucking on an SS2 turbo. Should be pretty quick once tuned. Hoping for 300 at the wheels
So we have got:
Haltech ECU
Tomei Cam Gears
You only need the one cam gear man... And also why the upgrade for the oil pump? Mine has held up so far with the abuse...
Might look into head studs and cam springs if you want to run bigger boost, these can be done on the car without lifting the head :yes:
Organise your entry for the track day in September hahaha
I might do. It'll be pretty rubbish as it's on standard shocks though haha. Also I have no licence or helmet or gear or fire extinguisher. I might aim for the next one hahaha
I have spare helmet and extinguisher you can borrow
Licence is easy to get $50
This is about as tempting as a kebab after a big night on the piss. I'll see how the build and tune goes with Paul. Might just unplug the boost controller and run it as rich as a Saudi prince if it's too quick for the suspension
If I'm going to upgrade 1 might as well do both.
I'd rather play it safe with the oil pump, minimize the chance of failure in the future
Might be an idea. What's the limit on boost with stock studs and springs?
Stock studs held up OK when i was running 24psi but eventually i would have done a headgasket... I would say 20psi on stock springs and studs to be safe as long as you have a good tuner... Others might have different opinions?
Most engines start having issues once they have been messed with (in regards to bearings and bottom ends and stuff) best leave it the way it came from Nissan and thrash... I thought mine may have proven that to ya by now :P
  • Like 1
Sounds good seeing as my MAP sensor will only let me run 21psi haha. I hope I land in a pit of money soon so I can come on the track day
if you use the intake cam gear you are going to lose your VCT as its a single unit and cannot be mated to the adjustable cam because well thats sorta what VCT is!.
go take it back and get them $$ back!
if not you could always sell it to someone else and they can flip it around and use as an exh gear.
The new clutch feels good, it will take a a little while to get used to it. Different friction point and it's a little heavier than my old one
Time to bed it in and get ready for track day next month :D
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
