I replaced my standard rear GTR diff with a Nismo 2way a while back, the best way to describe it is it makes the car a lot more predictable, it used to snap sideways when braking traction, now it just drifts perfectly. It was even more noticeable in 2wd when I broke the front diff recently.
I'm in the process of fitting a Quaife ATB diff after all of the positive reviews (like Piggaz) to the front.
Ford factory fit these on the 300hp Focus RS front wheel drive, and it got rave reviews for being able to put the power down without sledging.
Bought a Do-Luck DTMII G-Sensor unit. Should be interesting, it combines throttle input with g sensor readings to improve the Attessa.
As for the diffs, just want to test the 4wd first before thinking about changing the front diff.
Is it worth putting a quaife in the rear or is 1.5/2 way diff enough?
Anyway, now just waiting for the g sensor and wheels to arrive from Japan, then I can slap on the brakes, wheels, tyres and get her stickered up and ready to go!
In the meantime, going to pull out the shocks and suss out the suspension. Had some pretty serious understeer issues last time out.
Anyway, does anyone know where I can find these boot clips? They can be found both the Calsonic GTR and the Winfield car.
any ideas?
thanks Shaun, is there any advantage to buying the adjustable type?
Is it possible to buy these locally?
Because the latches are hard mounted it would be difficult to get the spacing between the latch and catch right so that it's neither too tight or loose when latched, having the adjustable latch would mean you can fine tune it and wouldn't have to get the spacing spot on.
Love what you're doing by the way, will be watching with interest :)
Some timing huh, I just bought my rims not long ago!
It's only a set of two though, and I would be looking long and hard to find another two to match.
Thanks for that though much appreciated! How's the Primera coming along?
got a Little time out on the Project we bought a house so i have a other things to do hope i have time for the Primera in the summer month :rolleyes:
regards Mario
Mario Mario Mario.........you know that the order of priority is GTR first everything else second!
kiddin.
Keen to see more progress of this build soon ;)
Tried fitting the C5C's. Got a few issues, one of which being the wheel nuts can't be secured as they aren't long enough. Also, not sure if they are going to fit under the guards when sitting on the ground. They have plenty of brake clearance though. Anyway, here's some photos:1896961_10153975789040301_1557877315_n.j
1536594_10153975789050301_1770344355_n.j
Anyone know where I can get super long wheel nuts?
if referring to these...
they are outside and 19mm socket too, but lock nut has got plenty of length on it. there are heaps of inside lock nuts, just need to shop around.
with wheels like that, i'd also be careful of how much thread you got available for the nuts. If not much, say hello to longer studs too. yay.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
