Yeah that is not what those turbos would be comparable to, they are much larger compressors than -5s and higher flowing for their size so while the lag may not be as bad as the increased size might suggest, it will still be quite noticeably laggier but they will also punch seriously.
Definitely a big single is the way to go for that requirement, there isn't really anything in the modern billet brigade to fit that small a requirement. There are 55mm HTA compressors but not sure that they are intended for GT28 cores and their flow is likely to be more like -9ish and better response if they could be used so too far the other way.
The EFRs start at 62mm and likely to end up -5ish in spool
I'm gonna be a smartass here and say twins are so back in the mid 90's like the old blitz, top secret, greddy, endless, HKS ect. Ect. Drag gtrs with the big twin GT3040's GT3037's GT2835's trust twin t67's and the twin blitz's and Apexi's. Also yes yes yes I realize these are not factory replacements lol but still twins with messy piping and what not are just old school to me haha. I do realize -5's -7'd -9's -10's have there place for a stealth police friendly look. I guess I'm just a whore for mid to mid/large size singles. :) I think singles have better drivability feeling and other reasons listed in other threads. Feel free to flame me twin lovers as I've had a few to many beverages tonight for the B/day.and thought I'd try to stir a couple members up. Lol excuse the spelling mistakes as I can hardly see the phone letters haha.
Cheers Josh
Agreed with above. Twins still carry an Oooo factor, but are long outdated nowadays.. I think it has been said elsewhere on the forum that the twin EFR's didn't live up to expectations? Perhaps that was a revised version, I am guessing now.
Either way, I agree twins were a back in the day thing. With the more recent advancements the concept is becoming redundant.. We can now squeeze big power from turbos with ultra wide powerbands, which defeats the purpose of twins IMHO.
Just my 2c
P.S. Happy B'day Josh lol
They involve more complexity than a single turbo but to make a direct comparison to low mount twins you need the big single to have an integral waste gate too . With two of everything you get two integral wastegates and the turbos housings can remain reasonably compact . With current technology you could probably use quite compact turbos on an RB26 if 209 Kw was the ask .
In favor of singles they're less complex but show me a twin scroll twin integral wastegate turbo and a cast manifold to suit . Then make it compact enough to drop the body shell over on the production line .
The answer in a current Skyline is to use a 3.5 or 3.7 litre V6 and if that isn't enough hang compact hair dryers off each bank . I'm not to sure how you go trying to shoehorn a huge single into a current GTR and expect to register it .
The downfall of the GTR/RB26 was lack of cubes pulling too many kilos in road form . Fine for a stripped out racer driven flat footed mostly but it's never the same in a luxed out emissions and noise legal road offering . Most homologation based road cars are like this , or I should say were like this because there effectively is no production based tarmac racing any more . The V8 Super Farts were a huge joke and nothing remotely like what you can buy new .
A .
I think that clip is confirmation that the twin HTAs are actually an awesome thing, especially if you are looking for an upgrade or alternative to GTRS/-10s. Looking forward to seeing how it goes on the dyno
the GT2868HTAs for GTR work out to $3071 plus postage ATM for two
you gonna step up from the -5s ?
Nah man. So much money when you factor in tunes, turbos, time to change them over. Considering I haven't run the car at full noise yet, CBF. Doesn't stop me from wondering how much better it would be though :D
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
