Hi Patrick, congrats on getting your R32 GTR.
Good luck with your rebuild.
There is a lot of good info on SAU.
I'm sure you've checked other build threads and the other good one is http://www.sau.com.au/forums/topic/93880-rb26-turbo-upgrade-all-dyno-results/
  • 3 months later...
Update:
Well we found the tell-tale cracks from the coolant jacket to the head stud holes and I decided to not use the existing block. I have an N1 block at the machine shop now and I had to get new pistons for the BC stroker kit.
I also found a chipped valve guide! yep a small part was missing and no doubt made it through the engine at some time so I went with BC bronze guides and while I was at it went with new +.5mm Stainless Steel valves. I also took the time to mildly port and polish the head as well. It came out great!
It sure has racked up the money on this build from where I wanted to be so I'll be selling the -7 turbos shortly to go bigger (for sure).
I'll keep you guys updated, but work has been insane this year.
Thanks!
Edited by HarrisRacing
  • Like 1
  • 3 months later...
Alright big updates.
Machine shop found the coolant cracks in the block from the head stud holes to the water jacket. LOTS of them. Scratched the idea of boring and using this block and purchased a NEW N1 block...and wow is it gorgeous for the first time in my life to have 100% all new parts to go together!
I ported the head, found LOTS of play in the valve guides including ONE broken one! Here's the new list of parts that I HAVE PURCHASED and RECEIVED:
BC stroker kit w/ sportsman rods
ARP main studs
ARP head studs
ARP flywheel bolts
Ported the head
BC +0.5mm OS SS valves for intake and exhaust (do not need to bore seats for these)
BC single valve spring and titanium retainers and new BC locks
BC phosphor-bronze valve guides
Tomei oil pump
Fluidampr harmonic balancer
Tomei Poncams A
Haltech Platinum PnP
Deatschwerks 800cc injectors
Deatschwerks Fuel Pump DW300
Mine's valve cover breathers.
Cylinder head is at RAWBrokerage getting final port/polish and assembly now.
BC completee gasket kit
N1 water pump
HKS timing belt
Z1 motorsports new silicone coolant lines (to/from Radiator)
New pilot bushing
New Throwout bearing
Tomei block oil restricter
Greddy Oil pan extension
OEM thermostat
Hicas Lockout (Whiteline racing)
Exedy Hyper Single VF clutch kit (likely won't work for my new power level)
Nismo clutch line
New NISMO floor mats (lol whatever I wanted them!)
Splitfire coils
New CV boots
Megan Racing Subframe bushings
Nismo clutch fork pivot
Nismo shifter bushing
Autobahn 88 silicone hose set
I measured and assembled the entire shortblock last weekend.
BC stroker crank, Sportsman Rods (good for a mere 1,200 HP), and CP pistons.
The CP pistons gave issue with clearance at the oil squirters. Seems they move the wrist pin in the piston design and don't increase the relief at the oil squirter. I took some measurements and started the grind / clearance of the pistons. Don't worry about the comparison picture, I disassembled all the rod/pistons and cleaned everything after clearance. Actually I pulled all the remaining ones apart once I had the measurements down.
ARP main studs. ACL "Race" bearings.
Installed Tomei oil restricter
Also getting all the valve covers powdercoated "2009 Ford F-150 Amber Gold Metallic". Should look pretty wild.
Then I am pretty much decided on single. PT 6262 or another shop's own 6262 build using the new Garrett GTX3582R 11 blade 62mm compressor on the same 62mm turbine rear as the Precision uses. Not sure about manifolds yet. Looking at .84 divided. They say these turbos have incredible response. Doubt I'l spend the money on the BB option.
As SimonR32 has done, I will be adding the breathing holes to my oilpan when I get the Greddy sump welded on. This forum is a WEALTH of information!
I will be running track days on the car and driving around for spirited fun on the weekends. I won a championship in the GT2 class in 2010 in my Toyota MR2 Turbo (which I recently sold, as well as my MKIV Supra TT 6 speed Hardtop).
Looking good so far!!
Oh...I also got approved for my personal plate. It's the first one I have had. I tried every spelling of GODZILLA or GOJIRA possible. They were ALL taken except for what I got "GODZYLA".
I felt it appropriate.
  • Like 1
Installed all new nissan cv boot kits on front axles last night while I had them out on the bench then moved to the greddy oil pan extension mods.
I saw another thread where a guy did something similar to this but after looking at it I may add some more holes (pictured) since the reinforcing ribs might hurt draining where the factory 3 sump extensions are.
What do you guys think?
Also, is it necessary to remove the differential prior to welding the pan? Are there any seals to hurt or replace in the process?
I would figure if the seals can handle the heat, leaving the diff IN would reduce warpage. I also have the old block to bolt the pan to when we weld it.
Changed the cut a bit. After looking inside the pan some more I didn't like the horizontal dividers. I made a decision to add some drilled holes at the bottom of the slopes on one side and to completely cut the other side off. I also added a small hole in front in the incident that air gets trapped up there.
I also am not going to remove the diff for welding and will instruct the welder to take his time around the diff and seals.
Also installed the tomei oil pump (as delivered with both springs) and N1 water pump. I was surprised that there is no gasket there nor on the rear main seal...interesting.
I'm also adding the 2x -10 fittings as simonr32 has. I marked and cleaned the spots.
Can't wait until the head comes back so I can throw it on the engine!
jeesus i love how this thing went from a tidy up to a rebuild with a N1 block and stroker cranker.............actually that happens alot
all the best with the build but i dare say you need to get rid of those -7s for something a bit more suitable..... dyno sheet with a precision 6466 on a HKS 2.8 below, would be wicked fun on a 2.9
Lol yeah the -7s will be sold off! It will be single turbo now if for nothing else but to clean up the engine bay.
Likely only a 6266 although 6466 and 5862 crossed my mind. I saw simonr32's track videos and realized how lively a 6266 is on his stock bottom end and got a serious chubby for that setup!
Ahh the slippery slope of GTR fixing.
And that Hypertune V2 sure would clean up the engine bay some more! (Assuming someone would trade one of my kids for it!)
  • 5 weeks later...
Updates.
STILL waiting on head. Pressure tested good, guides pressed out, they are blending the ports around the guides that I couldn't port with the guides in. So they should be doing work this week.
Turbo is selected and purchased. Borg Warner 8374 EFR w/ .92 IWG and I got this on a STEAL. Manifold is yet to be decided...may end up being RAW brokerage's new one for the 8374 EFR IWG, since it clears the AC and PS on R32 and they sell a DP for it.
The new clutch arrived. Nismo Twin Disk Coppermix. (sprung hub).
Also the Nismo 1.5 way front LSD arrived. I'll be pulling the stocker out of the oilpan prior to welding. I wish I could have gone with a Quaife, but in the US I would have had to order 10 of them. Didn't know but one guy with a Skyline GTR so that was out. Nismo seems to be the next best thing IMO.
Transmission will just remain stock and be ready to explode. If I sell some of my gun collection I could go OS88 as insane as that sounds, but if I'm planning on that then it doesn't matter whatsoever.
Woot for progress! (slow, but sure and it should be GOOD!).
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
