It won't want to putter around, it'll want to turn tyres everywhere!
Paulie Paulie Paulie , you do not have to disappear in a cloud of smoke going to Woollies :)
I am not going to change anything again, if it runs anywhere near what I want, thats farken it, no more of this shit!
Do they have a dyno and a tuner? It should start up and be run in on the dyno and tuned and then ideally you will get another tune when its done about 10,000.
Hi Bob, this is CRD they do cars internationally and have a pretty good reputation. Their work seems tough and stands up to hard driving.
I just cannot handle the time shit, there is no need for it , especially from a company that can do this type of specialty work.
2k is a plentiful run in period.
If I follow instructions, 1000k should do it, but that is like driving home and back to Sydney. I will be working the motor on the way home, about 350Klm, change oil, do another 500 and change again and do some more Ks, book it in and back to Sydney for the tune, hopefully for the last time to do with the car, well that is, if I ever get it back :)
Hi Like, .2L,? 2.6 t0 3.2 = .6L to help off boost ?
Luke has a 3.0, you have a 3.2. Basically means you're gonna have more grunt naturally without the aid of the turbo.
Some movement but the bonnet is back on why do that before all of the motor work is done , it would only get in the way, yes/no? see what has happened, you blokes have got me all paranoid :(
You will likely get a small vid of it running next week.
and you will be off to pick it up
That would be soooooooo GOOOOOOOOOOD!
But I will not hold my breath :(
4 bolts. 10 mins effort
makes it easier to work in the bay. Safer for the protection of the bonnet.
Saying that I see a lot just use an extension type bar on the bonnet to hold it up higher
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
