Finished installing all new stuff last night ... bar the new rims that are not here yet and front splitter in progress
i'll go get a wheel alignment and have a few tuning sessions to see how it goes
MCA recommended 11kg front and 5kg rear springs based on details I gave them about the car and tracks I run. We have more point and shoot tracks not a lot of high speed cornering unfortunately :angry: so he suggested a softer spring rate than usually apparently ... i'll go with what they say for obvious reasons and only $50 / per spring to change if necessary
from jumping up and down n the front and back of the car which I know is a highly sophisticated testing mechanism ...lol.. they are far stiffer and progressive than what was in there previously
MCA do a top job and you will be happy with the Reds... I just drove mine for the first time on the weekend with them and they were great!
We are altering the spring rates on mine but not by much :)
  • Like 1
howd you go with your first crack at decent aero ??
which bit you changing front or rear ?
ive opted for cheaper version first as I know i'll prob smash it lol
Aero was all set to neutral and power set to low while we get the suspension sorted :) In terms of spring rates i am waiting to hear back, will likely be the front and rear by a touch!
I have already hit the ground with the carbon splitter as my old BC's were useless haha
my BCs are bent. im looking for new struts atm - MCA worth the dosh say over bilsteins?
Keen to hear spring rates too bro :)
MCAs are getting amazing reviews James. Ask Matt @ Wooten if he tested his reds out yet.
^^ interesting you say Bilsteins also
the s14 next to mine in my garage is full setup 500hp 2j has $4500 worth of custom bilsteins in it... absolutely awesome to drive (and co drive in which is more often)
I know they are different cars etc etc but when we get mine on the track we'll both be driving both cars will be interesting to compare certain things...
other option was KW variant 3's but at $4000 odd I still prob would've gone to MCA golds for that coin for tried and proven etc
New rims arrived ... I gotta say although I like nice rims etc Ive never really been a 'wheel guy'... but I admit I like these :yes:
Also started working on the splitter, very trial and error. Im making it up based off what Ive seen others do and putting bits of ideas together
Sits 65mm off the ground - 185 wide, those tabs on the side are yet to be bent up. its 120mm leading edge from the airdam
The airdam is large with no lip on the GTR bar and few aesthetic bend in there I don't like but hey its a version I and my first go
The honeycombe ally core stuff with .5m ally either side is very light and strong... I don't know how it relates to anything else people make but I just have to fit the mounting points up to the chassis and I'm at total weight of 6.1kg so prob get away with about 7.XX all up
Its very strong as a complete unit and fits on like a glove, which is great
Any thoughts suggestions or input welcome !
Edited by bcozican
  • Like 1
first roll out with a lot of the new stuff on Friday arvo for a tuning session ... car should be fairly different to drive Id imagine, but don't know maybe not.. we will see
I think the splitter thing is worth a go for not much coin and just some hours toiling away - can only give it a go to learn
sh*t pics and all but front splitter nearly complete just some tidying up to do
Edited by bcozican
MCA spring update will come on the 29th of this month when i test the new rates... Will try remember to post in here for you guys! Dont want to hijack your thread but seems relevant to your build ;)
  • Like 2
Yeah go for it more info the better I think... good luck and let us know how you go.
Well first time out at tuning session yesterday everything mostly went well. Its a point and shoot track with only 1 high speed straight and corner the rest is twisty.
The car was very balanced the splitter didnt break haha and basically just has a few scrape marks on the bottom of it which tells me the ride height of it all is pretty spot on
Biggest thing I noticed so far was the braking.... the new combo massively shortens braking distance. But whether this is because Im carrying less terminal speed because the front is now a big brick or just the new suspension,splitter, is helping obviously unknown at this stage as all this is just seat of the pants but feels like the later for sure
Had an issue with brake fluid spat out of the new bmc.. it doesnt seem to be leaking anywhere under pressure but it spat from max level to half way down.....maybe cap leaking?? Or just too full and pressurised with higher temps?? Anyone had similar please throw me a suggestion so will look at that
Also will need to run some brake ducting blanking everything off the front is cool and all but brakes cook easily
Overall reasonably successful first test I think and going in the right direction
Edited by bcozican
  • Like 1
I think Ive said this before, but I love seeing updates on this. Makes me want to go make my heap of crap better! Keep it up.
Seat of the pants is usually right anyways. ;)
Edited by R31 drift pig
  • Like 1
You mentioned some new 2 piece Project Mu rotors but that was it? So what else has gone into the braking system?
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
