Take some spare undies when you next go for a full throttle run after you get the car back Pete. I'm sure you'll need them, just reading the graphs you can see how much of an animal this car has become just from those few changes.
You'll definitely be happy with the choices you made and now you will be able to enjoy the car shortly. Just be careful with all that power you now have.
  • Like 1
Fantastic results from the 6266
I have the same turbo on my built 2.6 and it made 450kw @ 25psi on e85 at Jez
Stroker engine is Realy spinning that turbine hard, love it !!
Can you post up your graph to compare.
It would be a great reference.
I am going on a diet so my adult diapers can handle it for a few days.
  • Like 1
Should sent a copy of that dyno to CRD... please explain your shitty tune??? but oh well.. good on ya pete.. glad you finally got the results and thats blood scary looking dyno result lol...
That JEZ... hmmm, one word "respect"... :thumbsup:
  • Like 1
HAHAHAHAHA WHAT THE HELL??????
That required capitals because that is a scary car.
Pete - dont be so quick to defend CRD "build" haha the engineer put the engine together the work shop did the rest and did a piss poor job.
Ran detontation and a leaky manifold etc etc - i would be asking for a refund on the tune at MINIMUM as its $1800 you could buy half a bigger turbo and run 500kw. You're too nice.
they risked the engine with a bad tune IMO. Its simple if it ran pre ignition for a second game over.
Edited by Stixbnr32
That pre ignition is a killer
Well there were a few things I was not happy with but that was yesterday and I have moved on, so all good :)
Still smiling, that is were I am at today :cheers:
Cannot wait to pick it up and a 250 Klm trip home :yes:
  • Like 1
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
