On 03/07/2021 at 9:59 AM, Dose Pipe Sutututu said:
Needs twins to be a GT-R, or be like Advan and put twins in a GTS-4, and put GT-R guards on it. GT-R with sunroof lol.
He argued that till he was blue in the face and went quiet after I hit him with “does the Japanese vin start with bcnr33?”
  • Like 1
  • Haha 1
On 04/07/2021 at 8:37 AM, WantGTR said:
This is genius
Then all the GT-R boys can do single turbo conversions and pop in NEO blocks to be GTS-4s.
@r32-25t you going to redo the engine loom too? I'm tempted at the moment as well. I stripped back the OEM loom and it's still good so kind of feels like a waste.
Yeah I will be replacing the engine harness, just look at it being almost 30yrs old and it’s out at the moment so may as well
  • Like 1
On 7/4/2021 at 2:29 PM, r32-25t said:
Injector have been changed twice and turbos 3 times
at least I’m not the mack daddy of the 80k rust bucket
850s
1000s
1250s
Then 1650s
come on Brett… I thought you did the maths, & do it once and do it right?
I’ll stick with my Mack daddy “rust bucket” thanks, at least it has a blue plate 😂😂😂
I’ve never had 850s
building cars is a journey and one I’m happy I took because I enjoy working on my car not writing cheques for other people to do it.
so unless you actually have anything useful to say I’d appreciate if you troll other parts of the forum, like I give you to the courtesy of staying out of your threads
Going a new OEM one or custom and deleting the crap you don't need like the AFM wiring?
AFM wiring actually turns out to be perfect for wiring in an EMAP sensor.
Going to grab the wiring specialties one and remove the wires I don’t require and replace them with ones that I do need ie. Load cell and pressure sensors a
  • Like 1
Because of needing the bay to go back to bare metal the shop tried to use stripper to remove the paint and because it wouldn’t remove the undercoat it was decided blasting is the only option.
89A87F5E-245E-4A47-9184-B2B054EF878C.thumb.jpeg.17990aaa9e57ba8a4ca7c2b3db2616f0.jpegD4718691-79C7-4EB0-BC73-FF66D42C3E67.thumb.jpeg.95bd040ae457070734d57f46c0f43e39.jpeg Because of that he wanted the cross member removed and while I was there I removed a the rest of the lines and grabbed plugs for all the AN lines
blasting is booked and so is the tow truck
  • Like 2
Somehow, it finds a way to escalate 🤪
  • Haha 1
On 11/07/2021 at 7:49 PM, r32-25t said:
There’s always these little things you never expect but I’d rather just do it and end up with a perfect job
Yep, I said the same, and now 5k in parts later 🤔
The parts I’d really like to buy is the brake lines, Nismo heritage have some of them but according to their pictures they don’t have the complete abs versions.
they have the lines that go from the master to the pump but don’t have the ones that go from the pump to the left and right fronts or the one that goes from the pump to the rear. And nissan in their wisdom made both abs and non abs lines the same part numbers despite them being completely different shapes and sizes
No, all the brake lines are available from Nismo for front and rear and the abs and non abs pipes are not the same part numbers. We replaced both the ABS fronts from ABS pump on the white 32 recently as someone had made some pretty average replacements. For example front left ABS ones are 46242-RHR21 (old part 46242-04U00) and non abs for left is 46242-RHR20 (old part 46242-01U10).
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
