Flat tyre yesterday... Nail goes in, Nail comes out... big hole and dropping 10psi in 2 minutes. Was running on the sidewall for a few km's, and it was only feeling mildly sloppy on the road... pulling slightly to the left. Only realised something was properly wrong when I booted it hard from the lights and the rear end started walking to the side.
Liam came and rescued me with a socket set and breaker bar, because top bloke.
  • Like 1
The tree is HUGE. Cutting it down will be a full day with people in the air with chainsaws and it goes across 3 properties.
The council here LOVE fining people for cutting them down.
Guy up the road got dobbed in by some nosey f**ker and the council were there handing out fines before the tree was even down.
That would make sense but I was actually ahead from the get go. Maybe shit reaction time from him but AD08Rs are great at launching.
He did show me his launch at the next lights and it moved but not impressively so. Seen GTRs move quicker off the line.
When you do your fast and the furious antics on this street, how far do you go? Are we talking 0-60 here or full quarter miles at a time?
Just curious as to what interval to live my life by
  • Like 1
Woah woah...not the street, this is Calder Park baby...
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
