No, it is never like that for E85... it also wasn't like that when I checked the intercooler piping about 20 minutes before the gasket let go. (because oil in charge pipes).
The Head Gasket is what has let go (or something else that mixes coolant and oil...) at most 150kms since a new gasket (Tomei!) and new ARP2000 head studs have been put in.
Surprises all round, really.
In the thread re: Different boost in different gears I also mentioned that this happens at vacuum levels too, it happens across the entire spectrum and is an Auto gearbox thing, the crash in the hills was at 30kmh off throttle entirely in the rain, across standing water and mud.
Did you have the head and block decked?
Sure was, by the people who installed the gasket! It may have been the head itself cracking. Time will tell. I don't immediately subscribe to 'they did it wrong' as this isn't overly likely
Always had iPhones.. now have s6 edge, meh both do what I want from them the thing I like about the s6 is purely not having to use itunes to import music etc.
Oh and dat screen doe
Edited by UNR33L
  • Like 1
aside from all the issues i had with my iphone 4 and work iphone 5... the work ipad functions flawlessly because its never been updated. the second you update your product to a new OS for new products, its f**ked m8
also i seamlessly installed a gameboy advanced emulator and Pokemon Crystal ROM on my HTC. took like 4mins and it functions perfectly.
As most of my music is torrented, iTunes is actually better than android folders. Neither of them play all my music but apple plays substantially more. Same goes for Samsung Keis
Get a better music player on android to play the formats you want?
Oh and built in screen mirroring to my tv mad too :D *starting to sound like android fanboy*
Edited by UNR33L
that and having the torrent client on my tablet, along with a VPN client
life is great
cannot be tracked, can download content direct to tablet no pc, then play on tv.
Any ideas?
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
