nahhh like 20 mins from home + toll charges for gym cbf. Dingley on way home from work go like twice a week.. lazy now that I live on my own #missdathomecookedmeals
Haha I've been in my place for 6 months and haven't cooked once. Especially with FIFO lyf don't need to do any #sundaymealprep & nothing fresh lasts until I'm back.
3 more sleeps then I'm off to India, was recommended foul curry... Anyone been to India?
I've been to India. Great place with amazing people and incredible life there. It is a massive culture clash when you first get there but if you embrace it you'll really enjoy it. Take probiotics and take them everyday. Just embrace the place and go with what ever it throws at you. On the whole they are very friendly, non threatening people. Have very fond memories of my time there. Enjoy.
Mick.
  • Like 1
ahhh k. must be lonely looking down from upstairs at all the peasants in clayton by yourself :P
i know right, all those dam peasants. Mrs wants to move in but I ain't ready for that shiz yet.
on a side note, waiting for the clayton south landfill to close up start of next year.. every so often get a waft when outside :\
True.. even when I am at home buying fresh food like veggies etc gets annoying because if I don't cook it just goes shitty quickly also cbf cooking like all these different types of veggies for just me.. my meat and veg is usually steak and some broccoli only :\
Edited by UNR33L
Nothing wrong with broccoli only
But you can buy some mixed steam fresh veggies - chuck in the microwave for a minute and done. Doesn't taste as good but you're not eating vegetables for taste.
no shit i totally forgot about those steamed bag things, used to have them all the time at parents lol
Mick.
Translation : it's a shit hole but if you embrace it it's a good
  • Like 3
I roast veggies for you!
^ no? (@ moh)
fark those steam veggie bags. cheaper and easier to just buy corn, peas, beans frozen and then microwave them in a tupperware container. then you can add them to anything you're cooking, whilst frozen. fresh is the only way to go for broccoli, cauliflower and carrot though.
This
I wouldn't describe 1/4 of their population living in poverty as an incredible lifestyle, but hey, I like water and food
^ no? (@ moh)
Enjoy washing your Tupperware containers, Indian
^ no? (@ moh)
the goat lovers shot down a russian warplane over syria...
? still got the mrs just don't live with her if that's what you asking :P
Moh weighed myself tonight, 78.something kg feels badman when I expected to see it a couple of kg less.. shit goes up fast when not doing gym :\ *proceeds to drink coke with dinner*
Whats your goal weight? 78kg isnt that heavy for your height? Or is it body composition
Whats you calorie intake to force yourself to eat brocolli etc? or do you like it? Or just to have your fruit and veg micro nutrients for the day?
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
