So... how does one organize what you did in Japan, Rekin? Did want to go to Japan and do something like that quite a bit, maybe even try and JDM road trip it but never really knew how to achieve it
Setting up some HP elite x2 (basically like surfers pro 3) and they charge from USB type C port, they have ONE of them and they also come with a USB type C to HDMI adapter.. so you can't charge the laptop and present through a HDMI cable at the same time.. smart HP :D
Edited by UNR33L
http://Www.fun2drivetours.com
  • Like 1
Terrorist.
Did a supercar drive thing around Vegas canyons and was sick as well, got to drive some jag, ferarri 458, and a lambo gallardo bout 20 mins in each car but on my own and flogging them a bit. Was rad.
That moment when I have new pulley and supercharger snout, big ass new brembos and rotors, but gotta save some more cash for the intercooler and cats before I get them all on :(
Edited by UNR33L
martin, hook a brother up.
start bringing in roids or something. dezz and birds can distribute. none of this legit sharemarket shit. VWL goin places. then we can all buy yakuza cars and be conspicuous.
Dezz you still riding brah?
Track only still? I been just doing supermoto.. not getting out as much as I'd like tho as usual with bikes :(
Went to Nitro Circus the other night, that was pretty cool
  • Like 1
Why the f**k do dat dere CEOs/lawyers/etc. buy Macbooks only to have windows installed on them then create a million problems for the IT fellows when shit aint compatible
"but it looks cool bro"
Edited by UNR33L
Yer I went on Sunday, was sick as
Dem 5 person backflips from the crowd lol, I spoke to a mate that saw the Saturday one.. they did the same thing with the girl on the front etc.. made us think it was a bit staged.
Mate is in transit to America right now.. Just got a photo from my other mate he's with of him in a random search (the one in a separate room etc). Last name Saad
hahahahahah, gold
im considering a murica trip next year, any interesting shit?
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
