I never said it's not way too much for the simple ass job he does....
Nor how f**king disgusting it is that he takes ~$95k to sit inside a comfy V8 and pull over non-dangerous, non-criminals while beat cops put their life on the line for ~$65k
Simply that it makes me happy that he had to work for over a decade to get to where he is and that being HWP he probably can't really get any further
  • Like 1
All of the truth
Problem with cops like him is they are fueled by a distorted perception of intrinsic reward that they're making some kind of difference to the community / are heroes of the same kind who save lives. Must be hard coming up against Melbourne's toughest exhaust systems. Will probably never wake up to the fact that he's made life harder than it needs to be for thousands of people who haven't done anything all that wrong - worse than a thief really.
Having spoken to other police in his station, he's not very popular amongst colleagues either...nor are other HWP for that matter.
Hamish what's the 'increment'? Years I'm guessing? That's what I hate about the teachers salary situation, goes up on years rather than if you are actually any good, good teachers deserve more than the shit ones
Edited by UNR33L
Years / Experience / PD Hurdles
"Salary progressions are based on a yearly Performance Development Assessment as per the Victorian Public Service Enterprise Agreement 2016. This online database forms the basis for all Victoria Police VPS employees’ progression criteria and subsequent raise in increment levels." - http://www.policecareer.vic.gov.au/vps/what-we-offer-vps/salary-vps
Edit: Leesh pops her head in for 2 seconds and its straight back to unfair Teachers Salaries ;)
What do you mean unfair, they only work like 8 months of the year
5...
4...
3...
2...
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
