45 minutes ago, UNR33L said:
Better off putting 5k on Adelaide this weekend
Was mucking around with Scorptec's custom build web app and came to a very awesome build with 5k. 1080ti SLI...
Also tried making the best PC I could within reason, using $2400 CPU etc. Came up around 10k...surprisingly cheap for the horsepower.
I'm tempted to up my gambling amounts but betting with overseas bookies is risky... Stupid government won't let me live bet online. But everyone else is allowed to piss their money away on the football at the touch of a button live because it's more popular than UFC. f**k off the sphincter of the universes
4 hours ago, TiTAN said:
Sli is such a waste of money. Nobody does much optimisation so you pay twice the money for 30% improved fps.
Yeah true, but that rings true for any flagship / top end product. That $2400 10 core i7 isn't twice as fast as the 8 core for half its price.
IMO the best balance between obsoletion and spending is the upper midrange. Last a good few years and allows an upgrade or two if necessary before another build. Or in my case make it last 10 years...
3 hours ago, UNR33L said:
Yeah SLI often causes more trouble that it's worth there's been numerous tests that shows stuttering etc
Big single FTW, almost like a GTR I guess.
Two big singles...can you not remove the SLI bridge and run off one display adaptor most of the time, then connect them when needed?
That PC I put together had two 1080ti 11gb, so unless you're going Quattro / CAD rendering cards, it was pretty much the best gaming card you could get at the current time.
No. You just save the money you would have spent on the 2nd card and buy a new top of the line one to replace your current card after a few years.
Braided E85 fuel lines in
I think the standard 23 year old ones did well to last 5 years on the stuff, but when it starts dripping fuel on your garage floor and you notice elevated levels of euphoria whilst driving it's probably time to do things properly
  • Like 1
5 years? That's decent run considering the amount of propaganda associated with e85 when it first came on market.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
