Tax folk: if company paying LAHA (the one that covers accommodation plus expenses) and its less than the stated ATO rate for that year, do you claim the price difference for every night its paid?
I can assist - PM me
Fun day out there :) Pity about the rain later on in the day.
Shoutouts to the VWLBBC members for showing up. Also, didn't get roped into a discussion about 88e once!
Spotted Pat, Leigh, Grant, Birds, Liam, Martin, Huy.... Only one of us crashed and needed to be skull dragged out of a ditch. Good times
  • Like 3
Yep awesome turnout.
Big thanks to the guys that stood out in the rain to run it as well ?
My car / driver of the day - the older bloke in the white r34 GTR, smashed it
Edited by UNR33L
  • Like 2
Yeah the targa GTR was quick. Also had some handy tools that really save seconds on hillclimb/motorkhana.
Dont know what happened to Shivams GTR. Has bad luck with that car... Sounded like drivetrain
Who was dragged out??? ?
Just as Simon said that he liked where i mounted my gopro before that run...
Massive thanks to the committee and helpers today standing in the cold rain!!
Special thanks to Grant for flagging down for me, Simon and Ryan for yanking me out!
  • Like 1
Turned out to be starter motor I think Chris said
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
