it fluctuates, but my 1080 & i7 8400 are churning out ~$100aud/month if left on 24hrs. That's with BTC price hovering like it has for the past 13 weeks. But since a recent update, seen a 20-55% increase in payout.
I think its important to come up with a gameplan for each cycle. I've learned a lot in the last 6+ months so hopefully can apply that next time and during the bear market.
Planning on buying a house later this year... so sadly will have to liquidate a lot. Using crypto as collateral for loans or mortgages is even closer than people think... I'm annoyed no one will accept anything other than house equity as collateral. That shit is sooo 1980's.
Cardano
'nuff said.
I like cardano as a project and wish them all the best, there might be money to be made short term, but when the project team dont give a shit about price, want to deploy it to very very poor nations, are academic focused, took 5-6 years to get the fundamentals where they wanted it, and aim to keep it as cheap as possible... doesn't spell well for long term investor gains.
  • 1 month later...
Best ad ever, the enquiries must be rolling in
Check out this 1998 Nissan Skyline GT-R V-Spec BCNR33 Manual 4WD.
https://www.carsales.com.au/cars/details/1998-nissan-skyline-gt-r-v-spec-bcnr33-manual-4wd/SSE-AD-7272590
  • Haha 1
100% justifies the asking price….
Makes me want to enquire to find out more.  It really got the juices flowing!
  • Like 1
Given benefit of the doubt, it could be one of these scenarios
Her: “You still haven’t sold that damn car yet; get rid of it; we need to make room for a minivan”
”I put the ad up…see! Just haven’t had any bites yet.”
  • 3 weeks later...
  • 3 weeks later...
On 9/2/2021 at 12:27 PM, Count Grantleyish said:
You buy?
That or the new RS3…which would be more practical…and more expensive…and not manual 🤔
Get RS3
They will make better racket guaranteed.
On 9/4/2021 at 9:25 PM, Leroy Peterson said:
no more subie? what about your efame?
Sold it just wanted a change, miss it though for sure. Took advantage of dat used market.
Working at car dealerships so seeing all the nice Audis come in tempted me away from the jap stuff for now.
Got an R33 again now for shenanigans, whats a good performance shop these days to make my R33 fast?
Edited by UNR33L
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
