On 9/7/2021 at 9:04 PM, UNR33L said:
Sold it just wanted a change, miss it though for sure. Took advantage of dat used market.
Working at car dealerships so seeing all the nice Audis come in tempted me away from the jap stuff for now.
Got an R33 again now for shenanigans, whats a good performance shop these days to make my R33 fast?
Rajab racing
I came to a conclusion last year: that most car workshops can't run a business and don't actually want your money.
Try making a booking at most places... "We're busy at the moment, maybe in a month or two, contact me then" "I'll get back to you in a few weeks"
Just make a booking ffs, it's not hard.
"Oh my work partner has my hoist at the moment so I can't do the job right now, maybe in 6 months time"
If I wanted a turn key job on the pulsar (a shopping list of small issues), my options are pretty much Racepace and a 5 figure hole in my pocket.
Trying to book the Gloria in for suspension work: legit can't book something in. Obviously lockdown doesn't help.
"“Due to the implementation of Australia’s unique pole side impact design rules (ADR 85), the Nissan GT-R will not be imported into the Australian market after October 31, 2021,”
Sounds like half of Lexus' lineup will also be axed. Good times.
  • 3 weeks later...
  • 5 months later...
  • 4 weeks later...
anyone know how custom plates work?
Sold car interstate.
I want to keep numberplates.
I want to get refund on my paid rego.
Vicroads wants a stat dec and money to retain the rights to them?
I left the pulsar rego to lapse with plates and no one gives a shit.
  • 1 month later...
  • 2 months later...
  • 4 weeks later...
  • 1 month later...
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
