Hi guys, I'm new to SAU-read a lot of your posts though & very helpful. I'm currently waiting to import Black R34 gtt in Auto(yes I can drive manual though prefer Auto slightly more) & I'm wondering if you guys know the maximum potential of an auto r34? Planning on modding it with all usual suspects eg 3" cat, intercooler, new ecu + e85 & upgrade transmission etc. what could I expect -max hp wise??? Thanks in advance
https://www.sau.com.au/forums/topic/458916-max-hprwks-for-r34-gtt-auto-manual/
The potential of a stock box? Not much more than stock power (with a tune)
Potential of a box with $3,000 spent on it? A lot more than stock power.
Don't chase 300rwkw+ with a factory auto, you're gonna have a VERY bad time,
Thanks guys. I sold my N/A r34 because I'm now ready to chase high HP. I have a performance guy/garage that I'm close with in Northern Melbourne & yes I will be going bigger turbo, maybe Garret. Just need to decide on tuner. Just need to confirm R31Nioid, if I upgrade "slush box" (auto haha) then I can chase 600-700 hp at flywheel? Thanks guys
Yes
Greg managed 400kw from his 34, but it is a built 2.8 with a built auto.
I would be looking to keep it around 300kw, for auto longevity, but it will need a valve body upgrade and large trans cooler at a minimum.
I have few grand to star Gtstboy but doing tax soon & expecting descent return as industry I'm in (not porn industry but am considering it) ha. Also Scotty- is Gregg's an rb26 stroked to 2.8? And sorry(I'm no expert) but what is a valve body upgrade?
I don't think there much money in the porn industry for a male , unless your planning on man on man..
cheers
darren
  • Like 3
It wil be fine..its a R34 auto...even if it makes 400rwkw, half the pulls it will only show 300ish..lol, then 250, then 350, then whatever the f**k it wants..lol
cheers
darren
Edited by jet_r31
  • Like 1
Nahhh Darren, no man on man here mate!!! Sorry to disappoint haha. Anyways, so Darren do autos pull all over the shop in kws? Ps. I will have more than 2 grand for modding, just over a few months or so. I really don't want to go manual-but if huge difference in kW capabilities then maybe think about it. Or try rb25/30 on auto with built box
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
