thought i better update my time
SAU Nickname: sav man
Car Make and Model: 1989 BNR32 (GT-R)
Circuit Name: Symmonds Plains
Lap time: 1:02.94
Modifications
Engine: RB26
Power: 311rwkw
Suspension: some tenebe crap, HICAS completly removed and locked.
Tyres: Nexen 245/40R18
Brakes: Porsche 6 pot monoblock 355mm rotors Front. Rear standard with Hawk blue.
Body weight: stock - HICAS
also http://www.motorsportstas.com.au/Symmons_Plains.php?sm=4 some info on Symmonds
Edited by sav man
Well after what seems like an eternity to me I'm finally back and marked my return today at Phillip Island with a new PB of 1.47.24. Not too shabby given it is the 1st full track day I have got through in my car since Oct 05 and that the tyres I was on (toyo's) were definitely a good 1.5-2s slower than the bridgestones looking at how much Scotsman could get back on me through the sweepers and under brakes.
Racepace FTW! :whistling:
SAU Nickname: Wogboy
Car Make and Model: 2000 R34 GT-T
Circuit Name: Symmons Plains
Lap time: 1:07.75
Modifications
Engine: RB25DET stock turbo
Power: 225rwkw
Suspension: SK Bilstien group buy
Tyres: Falken RT somethings 235/45/17
Brakes: stock
Body weight: stock
SAU Nickname: AMEC
Car Make and Model: 300ZX Z32
Circuit Name: Wakefield Park
Lap time: 1:09.742 = 8th place on the list
Circuit Name: Queensland Raceway Sprint
Lap time: 0:57.56 = 2nd spot on the list
Modifications
Engine: VG30DETT
Power: 529 RWHP
Suspension: D2 coilovers
Tyres: F: 255/40/R17 R: 285/30/R18
Brakes: Stoptech
Body weight: 1403 kg
Phillip Island
Circuit Distance - 4.44km s
1. JagR33, R33 GTR - 1.46.36 sec
2. Aaron34, R34 GTR - 1:46.51 sec
3. Snowman, R34 GTR - 1:47.17 sec
4. Scotsman, R33 GTR - 1:47.79 sec
5 ferni, R33 GTR - 1.51.35 sec
6. BBGTR, R32 GTR - 1.51.76 sec
7. Roy, R32 GTST - 1.52.00 sec
8. Rowdyr32, R32 GTR - 1.52.23 sec
9. provo, R34 GTR - 1.53.97 sec
10. Ant97GTR, R33 GTR - 1.54.01 sec
Reference Lap Time:
- 1:45.28, GT Production Mazda RX-7
- 1:54.14, APCC Honda S2000 (Aus. Prod. Car Championship)
I was running 1.45s last year at an Alfa day. I can't remember the exact times though... Top of the list for me please...
Also, I ran 1.45.5 around Eastern Creek last year...
Damn you Aaron, was hoping you woudn't find this thread!!!! :P
But he's right, I did see a 1:45.8 from memory on Racetime at PI, before they deleted all previous event results....
SAU Nickname: archie01 (Archie)
Car Make and Model: R32 GTR
My times:
Calder 22/10/06 1:04.96
Sandown 10/06/07 1:23.58
Modifications
Engine: Cam Gears, single T04z
Power: 320rwkw Calder, 350rwkw Sandown
Tyres: 245/40/18" RE55's
Brakes: Alcon 6 pot fronts, standard rears, Braided Lines, Pads: F - DS3000, R - Endless.
Suspension: HICAS lock bar, Bilsteins, Whiteline f&r sway bars.
My times:
Modifications
I've seen a dyno sheet with 380+ kw. What happened to the extra 30 kw?
I remember as we came out of turn 4 and onto the back straight and you were in front of me, I wasn't able to reel you in but you weren't able to pull away either. So I'd say we're line ball on power but you have me everywhere else :D
I can see you in a 32.......and i can see myself in a 34....wanna swap? ;)
Its always satisfying when you can actually keep up with a car in a straight line...always so frustrating to be losing out in a straight line and having to fight to catch them up through the corners and under brakes....lol i can only do it for a few corners before overdirivng and losing even more time :D
Power: 350rwkw Sandown
F#$CK me, no wonder you blew me into the weeds on the straights..... :thumbsup:
I reckon by the 3rd flying lap, my car is down to about 280-285 rwkw given how hot it gets and how much timing is coming out and how much fuel is going in. I'm shooting 3 foot flames on decel when water temps are over 100deg C.
Cheers
Andrew
Cheers
Andrew
It's all factory issue for the ducting. The oil temps are not too bad as the oil cooler is in the front bumper and angled for maximum surface area. I've still got my air-con condensor so it blocks most of the radiator at the front.
With power comes heat, so unless I ditch the air-con there's not much I can do apart from doing some work at the bottom of the car to direct some air flow up into the hot part of the radiator.
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
