On 14/10/2020 at 11:52 AM, Lithium said:
So far the only "modern" twins setup that I've seen which has generated a result which gets one thinking is the PMC/Integrated Motorsport R34 GT-R which makes >1100hp @ crank on G25 660s.  It's laggy as hell, but has a wide (like 6000-10000rpm?) power delivery so there is a bit of a swings and roundabouts thing going on there - you would NOT use that for what most are looking for with twins, not least because it's not stock location but instead some wild fabrication involved.  I don't expect there to be any major development with stock location twins as turbo tech isn't really the primary hold up, it's mainly packaging limitations imho... which is a lot of why I'm so pro-single on an RB.
BTW, this thread is hilarious to look back over.
Yeah, I've seen that and had the occasional chat with Pete about it. Big set up that's built for purpose.
I would be interested to see the latest Gen 2 GTX 2860's set up on a 2.8, I think that would be about as modern as it gets currently.
RacePace did a Gen 1 GTX2860 on a 2.8 with E85. It made 421wkw at 20/21psi which was a pretty decent result.
I ran out of turbo on my -5's at 419wkw with my 2.8 on 98RON.
The current Gen 2q's seem to have more grunt to them and would seem to easily surpass the previous setups that have been tried (to varying levels of success. I know that AdamLZ on the youtube's has a set to go onto the R34 which is in the build so will be good to see the outcome there.
Edited by Torque Curve
American dyno though so can only take those results when they come with a pinch of salt..
  • Like 1
They all claim to have 1 million percent more flow and made more power on made up dyno graphs, by whoever is building the turbos, but hardly ever translate into real world gains. I've seen it so many times. Then again a lot of people just care about a higher number on their dyno graph
  • Like 2
    • Mine is all -12, I’m running a dry sump in a billet block though
    • HG's high flow is not "bolt on". The core is shorter, moves the comp cover rearwards in the engine bay. means you have to deal with the inlet plumbing a little bit. This is probably something to consider with every "bolt on" turbo anyway.
    • HyperGear. Just get a high flow of the stocker. Good, reliable, and should bolt on. Yes it will want things like a retune once done, so you need to factor this in to your spend too.
    • Hi. Iam looking for some "cheaper" bolt on turbo on RB25DET NEO. I do not want "big" power just better reliability than the stock turbo which is "fot now" good but is old and i do not think it has "easy" life. One the Skyline here running some "temu" china Turbo but i dont trust those... Thanks!
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
