If you were to state your vehicle, then using "per tank" is fine as its consistent.
actually its not fine, fuel gauges are not very accurate and i would hope you don't run it dry so you are really just having a wild guess. You might still have 150km of fuel left in the tank when you fill up..
best bet to record your odo and litres needed to fill up over a period of time and work it out from that.
Without getting pedantic, the easiest way to collect data is to knock up an Excel spreadsheet.
Enter litres and K's at every fill.
Doesn't matter if it's 15 litres or 50 litres, same for the k's, just keep entering the data.
Your average will get tighter the more data you input.
But it's a Skyline, you know from your wallet if it's chewing juice excessively.
  • Like 1
km to a tank is a horse shit method.
Working our your fuel consumption is so easy:
1) Grow a brain
2) Fill up
3) Look at how many litres you put in
4) Look at how many km on the trip meter
5) Consumption = Litres divided by kilometers multiplied by 100.
6) Reset trip meter and keep on driving, satisfied that finally you understand what the f**k is going on
Eg 55L and trip meter shows 415km. 55 / 415 * 100 = 13.25L/100km
My last tank was 12.7L/100km city cycle.
96-98 RON, 300rwkw GT3076 with WMI kit blah blah, I went to the GC and back [round trip of from memory 1700km] with mainly highway driving but also had a day in Sydney and a few drives around the GC and I averaged just under 9.8l/100km.
But your motor is a lazy straight 6 until you boost it. At 110km/hr it is just in the brink of boosting and hard drinking - good actually, I know when I speed because the turbo starts whistling at me!!!!
And I kept a notebook for it, just so I could check, haven't really done it since - my burning curiosity was sated.
OP your fuel figures are crap, get a proper tune.
380km to "a tank" - filling up early and putting 50L in it = 13.15L/100km
compared with 380km to "a tank" and putting 58L in it (almost dry) = 15.2L/100km
15% difference, we're a long way from NASA
P.S. My car does 55 LOLs per WOW. +/- 30% :cheers:
  • Like 1
You'll get more economy if you lean more on the timing around cruise and take the AFR past stoich.
I managed to get mine doing about 9L/100km going up to Forster.
What you need to remember though if you go past stoich you'll decrease power and torque, richer mixers produce more torque.
Ideally you want to tune where pedal effort is minimum for a certain rpm and you're doing the same speed.
But that argument only holds true if you are not using multiple fills like on a longer road trip.
Im with the fuel Nazi on this one. Kms "to a tank" is useless and lazy. If you want to make any claims or conclusions based off your consumption you need accurate data in the first place. Ive heard some pretty wild numbers over the years like 150 or 250km "to a tank", putting you in the 20-30L/100km range
  • Like 1
There are too many variables to fuel economy.
Someone who drives 20ks to work in a non congested 60-90kph will get far better fuel economy than someone who drives 20kmph in a congested 60kmph section.
Someone who starts their car and drives straight into 90kmph will get worse fuel economy than someone who can get their car up to temp and out of enrichment at a leisurely pace.
Temperature plays a huge role too.
Comparing fuel economy to someone who drives different roads than you is pointless.
I moved from the coast where I was getting 12l/100 to the act where I was getting 14l/100 because of the location and roads.
I get about 220km to a tank.
Tank being 50L. Driving being a mix of highway and day to day traffic.
My AFR on cruise is about 16:1.
Your guess is as good as mine lol.
How many lols per wow is that? I mean l/100km?
You better start buying bp shares[emoji12]
A lean AFR may not mean its actually using a small amount of fuel. Unburnt fuel in the exhaust would still read as a lean condition. So that could mean poor injector timing, poor fuel atomisation etc..
Otherwise the timing is just way too retarded for that AFR.
It's because his foot doesn't understand anything but throttle 0% or throttle 100%
The last car i tuned managed to double the factory power output at the wheels and went from stock ecu with 13psi 260km to 280km around town 330km highway. Made 153 wkw
To 22psi 450km to 460km around town to 550km to 580km was my absolute best driving to Melbourne!
street tuned but amlost maxed out the Z32 afm est 250 to 260wkw
was so excited about the 580km i almost came unstuck on the Monaro Highway in The National Park.
best way to test your fuel economy is to run out of fuel completely I guess.
Those bends tho[emoji3]
On twice the power output.
Tune was safe as and could be bashed on no matter how hot it was outside.
Edited by mr skidz
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
