I ran the 9180 IWG on my 2.6L rb26 for a bit.  It was on full song by 4500 like chris said - but that's a tiny bit laggy for my preference. It made 750whp and broke my R33 trans 4th gear.  Then I installed an R34 6speed trans and really began to appreciate the turbo.  Now that i am putting the car back together i will probably go to a 9174 IWG next
Ok so take my engine specs for example. 2.6L, Como ratio upped to 9.0. 260/10.8 cams with e85 I the tank. Would that be responsive enough for circuit work if I stay with the IWG rear housing?
my car is 2.6L and circuit only - I rarely drive on the street unless driving to the track.  4500rpm spool is late for the small track.  9180 gives violent acceleration.. with a nose heavy RB26 up front, i felt it was too much turbo for this stock displacement on tight tracks.  I prefer spool by 3800-4000rpm so the 8374 was perfect for that.  I expect 9174 to bridge the gap and will try that next. 2.8L might be the solution in the end. also the 9174 has the alloy CHRA and saves 7lbs so thats a bonus!
Edited by Full-Race Geoff
  • Like 1
So based on the posted mph these turbos are performing pretty close to the GT35, GT42s or old tech equivalents, 120ish mph about 340ish kws and 134 mph about 420ish kws. What's the advantage of this new breed? Most GT35s are making 20psi by 4500 on the 26. Am I missing something?
Response for road racing or street car is what you are gaining as well as a very compact package that usually saves money if you add up all other parts. Just price a ball bearing garret or precision, plus a gate, plus BOV, plus piping to route WG back to exhaust and you'll find the BW EFR is very competitive in price and features (if not the best value).
If you want a drag car and don't care of bottom end or mid-range response it really doesn't matter and every turbo manufacturer will likely give the same response. Again my car is just one example at only 18 psi boost. But i can tell you that it responds extremely well for a street turbo!
EDIT- i priced a BB CEA 6266 with wastegate, bov and came up with around $2250. Full race has the IWG .92 8374 EFR for $2450.
You'll die but I got my 8374 EFR .92 IWG for $1640 because it was priced wrong on ebay and they honored it. I'm sure they meant to type $2640 but heck it's on the car now so mine was an absolute no-brainer and probably not repeatable.
Also i think a 1.05 housing would be a better choice on my stroker, but I like the simplicity of the IWG. If I feel the 8374 isn't enough (and I'm contemplating it) i may go to the 9180 which is easy swap and I'm sure will have enough turbine flow on the .92.
  • Like 1
Also it should be noted that I don't run "antilag" I only have a mapped rev limit vs. speed. At 0 speed I have a 5500 rpms limit that actually is setup to soft cut at 250 rpms before the limit (5250). This limit goes back to 8250 (essentially start soft cut at 8k) everywhere over 2 mph. It's a simple table to make. I found that if I launched with any sort of plus fuel and retarded timing antilag the turbo would spool so fast I would blow tires off the line every time. Just a note...VERY responsive turbo. My brother drove the car home and was just astounded at how well the turbo works with the car for drivability. And to think I'm not on E85 yet and it's likely got 150 more WHP in it!?
That's a ~400whp terminal speed... Seems a bit light on for a turbo this size even at the low boost level?
To be honest i was thinking that i need to go to another track as insane as that sounds just for good measure. I mean it could just be hooking that good but I'm only on 255 hankook RS3 tires (yes 200 treadwear sport tires) and HKS's stiffest coilovers. How about the 1/8 mile time and mph? Perhaps it's just falling on it's face on top? It sure doesn't feel like it!
Also I attached my old time slip from this summer. I find it odd that i could have gained 5mph in the 1/8 and less than 2 in the 1/4?!2840c77773ffd7cfff7dfebb4b197fab.jpg
Power its probably closer to 460kw i'd say. its a 33 remember so its got at least 100kg on the 32s. Based on that MPH vs power thread I think some of the lighter 32s were acheving similar mph with less power.
There's the weight and the fact it is a stock motor and box so i'm going easy on the revs and gear shifting.
I could also screw another 5-6 psi into the thing if I'm feeling brave and pick up another 50-60kw.
All things considered I think the mph kinda backs up the power. Certainly wasnt running 500kw on the night.
The BW is just another new tech turbo at the end of the day. I think some people have talked them up to be the best thing in the world. The Precisions and the Garretts of the world seem to work better at the top end and are likely to be better suited to drag racing.
The Borg Warner is  epic on a street setup. Make meatier power in the middle
Edited by usmair
Thing is, there are ways to measure it. Would you run a standard RB26 to 13,000 RPM, then when it dies jump up and down saying the engine is badly designed?
Operate the turbo within it's parameters and you'll have no issue. How is that different to any other mechanical item?
  • Like 1
Don't think just because you put a speed sensor in there that they won't blame you for over spinning it.
How many people do you think that over spin these things and break them will quickly pull up the log of the turbo RPM and send it directly to Borg Warner?
I doubt there would be one and they're not stupid enough the believe otherwise.
  • Like 1
I do not care what you buy, you can choose anything and if you abuse it or take it outside the Warranty recommended usage guidelines and stuff it, bang goes your warranty.
How many of these EFRs blow up. If a speed sensor can protect your turbo , you would be a DH not to use it ?
I thought they used the EFRs in all sorts of racing , except for the hard core drag racing ?
Anyway, went for a run in Niks R on Saturday arvo , as s2d4 said and could not be a much better example than Niks car, right turbo for how you want your car to drive and Niks car proves the point, one FUN Skyline and a neat ride, thanks NIk :)
  • Like 2
Nik is who? SAU username? What's the specs on the setup?
5 hours ago, mr skidz said:
Because it gives the manufacturer an excuse to not warrant a product that decides to fly part and then pass the blame on to the consumer it happens all the time.
Nitto/HKS/JUN/Spool/Whatever says there bottom end is safe to "X"? If you throw a leg out of bed, how do you claim warranty?... Good luck!
A turbocharger is no different.
One of my -5's had shaft play like nothing else within 5,000 kms. Did I claim warranty? No. Were they operated out of what they were designed to do? Possibly!
  • Like 2
It looks like it  lays over a bit  up top in all those time slips posted
cheers
darren
Edited by jet_r31
Intune, I might get it wrong as I had a few reds , RB30 , efr8374 . 1.05 RH and Poncams   9.15 , Bs I think. If Nik reads this he might sort out if I got it wrong ?
He had -5s before and thought they were pretty good but said the EFR smashes them for response and transient response. It does not miss a beat.
If I had any doubts about swapping my 6266 Gen 2 for the EFR to use on the street , the doubts are gone , have to go to the Piggy bank again :)
  • Like 2
8 hours ago, JH32 said:
double quote, bloody computer, having a lot of trouble with the site but I think it has to do with my security ?
Edited by Nismo 3.2ish
double post
cheers
darren
In these for sure. But what I'm saying is compare these with my new 11.1 and then compare that to usmair's run (on high boost). In still 99 mph in the 1/8 mile and only gaining to 122 in 1/4? Doesn't make sense to me because the car feels strong all the way up (see video) and it seems to be inline with others videos for similar times.
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
