1 hour ago, Lithium said:
Interesting - I would have expected more than that!    Still, must be pretty solid even with that?
That doesn't sound great :/
Yea, I'm not sure about the oil/wastegate, but it only seems to be a very small amount and only when I'm really hard on it. And 750awhp is pretty nuts already. If there is more, I am pretty happy with where it is now. It just pulls and pulls all the way to 9k rpm. I've already gone through a back set of tires from spinning 3rd and some of 4th.
On 9/2/2017 at 11:40 AM, minesskyline said:
After speaking with the tuner further, I believe that 750 was all he could get out of the setup. If they can do more, I don't know what other changes could be made to extract more power.
im interested to see the chart, and whatever info you can share of the tune/setup.  how much boost, ignition advance and WGDC? Do you have turbo speed sensors?  Do you have a boost chart showing RPM vs boost and where are you reaching 1bar boost?  obviously there are many changes that can be made to extract more power, but thoroughly understanding the baseline is important before changing anything else
On 9/2/2017 at 11:42 AM, minesskyline said:
@Full-Race Geoff Do you know why the wastegates would allow small amounts of oil to be blown out from them? I have the turbosmart wastegates from your site.
All wastegates internal or external will have a small leak from the lower port.  In the case of turbosmart IWG actuators, if you use a 4 port solenoid with pressure in the lower canister it can push assembly lube out of the lower bushing. Turbosmart is fantastic to deal with, if you have any concerns send them a photo of the actuator.
On 9/2/2017 at 7:22 AM, Piggaz said:
@Full-Race Geoff
Have you seen a 8373/1.45 result at all?
Any news on the 8474?
yes 8374 1.45 was a popular evoX turbo, but 9174 1.45 has pretty well displaced it
8474 and 9280 both required a new compressor housing design.  This will not be released until 2018
Here's the 91 pump gas and e85 dyno plot overlay. Let me know what other information you need that's not represented here. I will get whatever you need. Also, I'm running a megasquirt standalone so I might be able to get the tune as a whole. This is not to say that the tuner did not do a good job, because I believe they did a fantastic job with this build.
Edited by minesskyline
Added more info.
now hit the track and tell us the mph you run :)
  • Like 1
Can't really read from the graph (sorry blurry and at an angle), but what power did it make on pumpgas (looks like 620?) and what boost level to achieve that? Same question for E85. Dang...mustang dyno those are STRONG numbers!
Sorry, I will take a better picture. 641 on pump at 26psi. 758 at 32psi on e85. The car is really fast. I've been in 9 second cars before and I am more than confident that this is one. I will try to get setup for the track this year to find out officially.
Oh that's interesting - that sounds a LOT more positive than I expected, what size cams and what headwork do you have again?  Normally 758whp on a US dyno doesn't necessarily represent THAT fast a car.
Aren't Mustang dynos meant to read low or realistic by Oz standards?
I am not sure they are totally consistent, my general feeling is the order of "generous" to "heartbreaker" for your average example of each would be Dynapack=Dynojet, Mainline=Mustang, DynoPower (Popular NZ dyno), then Dyno Dynamics... but then there seem to be more generous and also harsher examples of all of those which throw the rules, rules of thumb for dyno comparisons can't ever be taken as gospel from my observations so far.
Sound Performance use a Mustang dyno and they made ~770whp (over 550wkw) out of a 1.05a/r EFR8374 on kill with a hot 2JZ - if that was an absolute then comparing that with this result basically kills the "twins are better" argument for EFRs, which to be fair is a tricky one as there has not yet been transparent public result for twins which have justified their use over a single EFR that I've seen beyond where the twin kit covers what no single EFR can do (ie, twin EFR7163s flow MUCH more than any single EFR).
Edited by Lithium
  • Like 1
Port and polish, bronze valve guides, retainers and valves (I don't remember the brand off the top if my head). Cams are Poncam B's.
btw i now have a 34 getrag with a triple plate clutch sitting on 275 Mickey Thompson radials
im going to try and hit wsid in september, shove 31psi down its throat and better my 134mph
Edited by usmair
  • Like 2
Currently changing from Haltech platinum to EMU Black. Also resetting my out of spec shims (been this way forever), and going to water/meth injection. 20 psi is 126.7 mph now. I can't imagine 27-31!
Good way to find out whether the overspin problem is instant death or not. Garrett rate their wheels to near-similar maximum RPM too and people don't really seem to care much about spinning them way past it
Please post results :P
This is kind of a good point which I've been meaning to ask @Full-Race Geoff...  or anyone who has found anything, I've never seen any official Borg Warner documentation on the maximum recommended turbine speed for any of their EFR range - same goes the Garrett range?!
They both have the rpm lines on compressor maps, but there is nothing stated to indicate that any of those imply a maximum rpm - which from all I can tell is treated like a single magic number.  Is there any information available we can refer to?  There has been much noise made about how risky it is to go past the max rpm of any of these turbochargers but without that max rpm I feel awkward sometimes bringing it up without any supplied information.  One of the justifications given for the EFR9174 existing is that it allows for more rpm safely, which implies that the compressor wants to spin faster than the turbine can happily spin at - but that is a number which we are not given... obviously going off the compressor map will result in rpm skyrocketing to try and move any more air as compressor efficiency plummets but surely the intention of the 9174 isn't to encourage running the compressor into uncharted territory?
Clarification would be awesome :)
I've got the EFR speed sensor on my S15 (SR20DET). Hits 29psi and tapers to ~23psi. This peaks up at ~140,000rpm (can't remember exact figure). Max turbine speed for each EFR turbo is well documented, pretty sure it's in the manual. My 7163 is 'rated' to 150,600 rpm. Full-Race website lists that the EFR 9174 turbine RPM 'max' is 125,000rpm.
I bought the sensor so I could push the turbo to it's top end limit on my engine and still feel a little 'safe' in that it was still within manufacturers specs.
Awesome, obviously I am missing something then - I've tried looking and so far can't find it, can you please point me at somewhere which either
a) Specifies specifically that the turbine speed should not exceed 150,600rpm (which is coincidentally the last rpm line on the compressor map, which doesn't have to mean that it's at all linked to max turbine wheel speed
b) Clarifies that the compressor map is constructed to sit within the confines of the maximum speed you should spin the turbine to.
I research these things quite thoroughly and I've not seen anything beyond the Full-Race website's "125,000rpm" limit mentioned - that is the only time I've seen a limit mentioned, and it doesn't refer to any Borg Warner official specs I've seen, and I've certainly not seen that in any of the Borg Warner spec sheets I've looked at.  If you are investing heaps of money and intend on pushing hard it really would be nice to have some more clearly communicated specs on this.
I'm not saying that they aren't there, but I have no found anything which I consider clear and exact so admit that I may have missed it but I'm certainly not the only one who hasn't seen it specifically outlined for the whole range and would benefit from that being clarified, so pointing it out would be very appreciated!
Edited by Lithium
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
