3 minutes ago, GTSBoy said:
It needs to, otherwise there is zero point in making the manifold split pulse.
I was going the single gate route but got talked out of it.... No regrets!
  • Like 1
Won't quote names but I've seen a few from big brands appear to be split until both pulses are just going into 1x big 50 mm hole to the gate.
Best I've seen from one brand was an open scroll manifold with a divided T3 flange welded on top lol
  • Haha 1
yeah 6 boost did the spilt for the gate.
I did all the fab work, trust me you dont want anymore pipe work under there. In saying that my gate is plumbed back in which makes it a bit harder. Screamer pipes are easier to route.
But at the end of the day, what for - why make it harder and most $$$ for the same result.
Edited by Deano 1
  • Like 2
Also the plate thats welded up the inside of the pipe from the mani to gate flange - Hangs out past the end of the pipe, once you weld the V band onto the end of the pipe - you than shape the "spilt plate" to suit the back of the waste gate, so its sealed up.
  • Like 1
This would be practically no different to the IWG housings, and i'd be pretty confident that it would be as good as twin gates.
What stumps me is when people do have a split pulse manifold and the single gate isn't divided..
  • Like 1
Given r32-25t has posted a dyno of his -5's with vcam on the same dyno presumably as this i thought i'd put them together for interests stake.
Of course if ramp rate was different etc might cause comparison issues but i figure this is better than most considering its same dyno and a short period of time apart.
  • Like 4
For what its worth, going on boost curves etc, i'd expect my 2.8/9.5:1 8374 to be to the left of the -5 curve. But its hard to say if street feel would line up on a dyno etc.
But yes if i had another spare 5000 i'd get vcam.
Your car would belt the 5s just like every other back to back 5s vs 8374.
Plus a run in tune would be low on timing I'd like to think which should fatten up the middle a bit more.
V cam on your car would probably just induce surge. With the hi comp and .92 it wouldn't need any help getting it spooling!
Piggies car would start surging on the dyno as low as 2800rpm.
So even if it had v cam on it, you couldn’t move the intake cam anyways.
Edited by Mick_o
New EFR crew member checking in....
Manifold will be a 6boost w/ twin gates.
Wastegates will be tial mv-s.
Exhaust will be plumbed back via 3.5" downpipe
The EFR will be used on a SR20DET with a fully ported NAPREC head, big valve chamber with deleted squish pads.
ETA for completion is probably 6 months away.
Having been in a 2.8L EFR machine, the thing is completely mental and beats stock response with quadruple the power.  THEY ARE MAGIC fellas.
  • Like 1
21 minutes ago, sneakey pete said:
might plot that tomorrow arvo if i get a chance.
Note the one i already plotted was -5's with vcam.
As the pig said thats also the same v cam and rolling road not hub dyno like the -5 result. So theres a possibility that its a "higher reading" vs the rollers.
Tell em the turbo son!
Because I was worried about the exact same thing I spoke to Jez about that and his dynos are within 3% of each other
Sweet thanks for clearing that up ?
So lets call it "on par" you're at about 160kw at 4000.. The 8374 is at about 240kw at 4000??
80kw through the middle with 60kw up top.
Thats quite alot more power EVERYWHERE!
Plus all those nice things EFR delivers that the dynosheet doesn't show...
Edited by Mick_o
I'm happy with mine also but coming from Tomei ARMS that wouldn't be a glowing endorsement :P
did take it for a bit of a moutain squirt last week and its great, no 'to large to be fun' issues... and (once i get e85/boost) will have a shitload of power for whenever else i want it
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
