9 hours ago, reaper said:
Just remember if comparing to mine it was done with the 6 speed and 3.545's so not exactly like for like vs 5 speed and 4.11's :)
It still belts the 5s any which way you look at it ?
Its 7lb bigger than the 5s too so the most impressive thing is the 80kw in the middle. Not just the top end number it kills it from the basement to redline..
Another interesting thing is that it looks like the gains would probably be better to just going to a single EFR than using v cam to try getting the twins on song sooner.
Even so you dont get the killer throttle response or how quick the EFR stands up on the street.
More power everywhere and its also alot smoother and linear power delivery than the twins.
So another win if you are on track as there really is no "hot spot" even if you apply half throttle its not gunna give you 90% of your power like the twins do.
You only need  half power for a turn?  Apply half throttle and thats all you get!
Piggies car actually made 240kw at half throttle outta the 486kw he made on the dyno.
No other turbos do that to my knowledge?
Edited by Mick_o
On 12/21/2017 at 3:27 PM, BakemonoRicer said:
New EFR crew member checking in....
Manifold will be a 6boost w/ twin gates.
Wastegates will be tial mv-s.
Exhaust will be plumbed back via 3.5" downpipe
The EFR will be used on a SR20DET with a fully ported NAPREC head, big valve chamber with deleted squish pads.
ETA for completion is probably 6 months away.
Having been in a 2.8L EFR machine, the thing is completely mental and beats stock response with quadruple the power.  THEY ARE MAGIC fellas.
No VE Head ? Stock stroke ?
What EFR are you going to use ?
I should really get my s15 finished at some stage !
DET head but very tickled. Stock bottom end. When it pops a 2.2 with possibly a VE head will go on it.
Benny can let you know with turbo choice. It’s smaller than a 8374 or 9180 though. ?
I would just keep that head on Benny's and slap in better springs, slightly more aggressive cams and 2.2L it's mum all round.
No need for VE if you're not chasing silly numbers. A clean S14/15 head with carefully chosen parts ie not GT3071 and open scroll junk will be perfect for his requirements.
2.2L with his head, VCT, TS everything will happily make the power and deliver the boner response he would be after.
Once the box blows, put in a 5 speed Z32 and an convert his diff ratio to 3.9 from an auto.
  • Like 1
Nothing, and I mean no turbo in the world can spool up quite like an automatic gearbox will do it with a decent stall converter.
Going manual has certainly taken the buzz out of my EFR as everything seems laggy comparatively. Until you want to take a corner and all is forgiven.
  • Like 1
  • 4 weeks later...
Here is a mate's 2.8litre EFR9180 setup doing some laps at NZ's time attack series - bonus loose moment at the end of the timed lap :)
https://www.youtube.com/watch?v=3klPPfce7W0&t=2m20s
  • Like 3
  • Thanks 1
Mine makes boost, needs more fine tuning and even more boost, got a missfire and a few other little niggly issues and then back at work. So still no 'final result'
Edit: E85 though which is great to have
Goes well though, can still hit full boost (25psi) in second gear with 50% throttle which is a laugh
  • Like 1
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
