2 minutes ago, usmair said:
515kw @ 30 psi 109,000 RPM turbine speed.
Stock head not too happy and very close to 116,000 max speed
Next stop 32psi
Wasn’t it a stock bottom end with a built head?
Next stop 32psi
That’s awesome man, fkn crazy I tell ya what. I’m very impressed [emoji1362]
Allhamdullilah the dyno was facing Mecca huh mate [emoji6]
  • Like 1
its got more in. Definitely does, BUT:
- I've got a stock bottom end
- I'm running 35psi on the fricken thing with ARP 2000 studs
- AND I'm already past the recommended turbine speed.
580kw @ 35 psi will do me.
Will put up dyno sheet in due time.
  • Like 1
Well done mate good on you, hell of a result [emoji1360][emoji1360]
All I see are excuses :)
Should go very well, keen to see how fast it traps. What dyno is it?
Jem dyno. Should see 140mph.
That's what I told them. Dyno figures can be up down left right. My target was 140mph.
Will be out to WSID when I can to run it.
  • Like 3
That is a huge result - nice work! When do you pick it up? Keen to hear how you find it.
I assume the 580kw run is a glory run - while you probably know it anyway  would recommend dropping it down a little just to be safe, the extra 20kw on a stock motor probably aren't worth the strain.
It's an awesome result even at 116krpm.  The compressor obviously still can move more air but what the concern is that it has to work harder and harder to move any more air, which means at the point you are at the turbo rpm can start spinning a lot faster for much smaller increases in airflow which is where the overspeed thing comes from.
Cheers for sharing the results - wicked to see and some good data there :)
Will try pick it up tonight and comment on how it's behaves in the road.
Staying at 35psi. Now I'm tempted to have a crack at running a 9 haha.
580kw is at 7000RPM. I'm getting 35psi by 5500RPM.
Going to try and get an overlay on the 8374 dyno and 9180 dyno runs and share it.
    • Hi GTSBoy, Excuse my ignorance but what does a "Bad" Knee point mean ?
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
